Page 12 of 29 FirstFirst ... 2101112131422 ... LastLast
  1. #111
    While the cable you have would work, and many people use that I'm sure, if you look in the manuals for 2.2kw drives you will see that 2.5mm^2 is generally recommended.
    Also I think it's a good idea to take an earth directly to the spindle because if you have a motor to earth fault a lot of current will flow, if you don't have an earth wire it could flow though the bearings finding a path to earth and this could ruin them. If you were selling these things commercially they would have to meet regulations which most likely also encompass manufacturers recommendations, but if it's for yoursefl then you have to decide how far you want to go.
    These spindles only pull at Max 8amps the VFD manual is recommending to cover all bases. 1.5m/2 will easily handle 8A or anything you throw at these spindles. I've embedded my spindle in aluminium many many times pulling many amps stalling the spindle and loading it to the max without any issues using 1.5m/2 cable.
    The machine should be earthed and adding another earth could create an earth loop and potential problems, it's happened many times before. The VFD is earthed and the shielding should go to the VFD earth point and that is enough. IME.!!
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  3. #112
    Well fancy that, all you time served people out there, you wasted four years of your life, it seems you didn't need to know all that stuff after all.
  4. The Following User Says Thank You to EddyCurrent For This Useful Post:
  5. #113
    Keep your knickers on Eddy wasn't saying your wrong or questioning your knowledge I'm saying 1.5mm is fine with these spindles after fitting many of these spindles without any troubles at all.!!. . Which I can't say about those being earthed at the spindle because I've had a few and seen several instances of people doing this and having ground loop troubles.
    Also 2.5mm doesn't even fit the spindle connector so I doubt they where designed to use 2.5mm.!
  7. #114
    my Chinese spindle and vfd arrived today from Portsmouth.the coolant ports as can be seen had fittings previously fitted . i don't know if this is standard practice ( as in testing) or it's second hand spindle and passed on as new. if any one has a previous experience of this i would like to know before i go and contact the seller.
    the VFD appears to be new and doesn't have any sings of previous use. Then again what do i know!! i had a read of
    http://www.mycncuk.com/threads/5814-...HINESE+SPINDLE to try and get to grips with the set up procedure . i'm curious to know if the settings listed in a post by Shinobiwan ( post 6) are still applicable . they are 2 years old but would save some unnecessary manual reading.
ID:	14738   Click image for larger version.
ID:	14739   Click image for larger version.
ID:	14740   Click image for larger version.
ID:	14741   Click image for larger version.
ID:	14742   Click image for larger version.
  8. #115
    Yes this is normal for them to be taken out after testing. They used to leave them in and they often got snapped off in transit, ive had many come like this. If the body was scratched then I'd be suspicous.
    The settings Ant (shinobiwan) posted are still the same I believe.
  9. The Following User Says Thank You to JAZZCNC For This Useful Post:
  10. #116
    cheers Jazz , I didn't fancy getting into a paper trail with the supplier. the body looks fine , no evidence of a mounting bracket. i had a read of the manual and to be honest it would take another good couple of reads to filter out the stuff when compared to Ants post. i'll still need to go over it once i hook up the bob with spindle control. but at least i have enough info to get me testing the vfd with the spindle. thanks again.
  11. #117
    do i need an internet connection to set up the PLCM-E3 OR MACH 3? my garage is a blind spot for a decent signal.
  12. #118
    Quote Originally Posted by PAULRO View Post
    Not for Mach3 but for the PLCM you may need certain windows system programs like DotNet etc to install plug-in and driver etc, depends how upto date your windows is.?
  13. The Following User Says Thank You to JAZZCNC For This Useful Post:
  14. #119
    I think you just download the plugin to a usb stick then you can do it without a internet connection. You might be able to use some homeplug adaptors like these http://www.diy.com/departments/tp-li...150301200758:s
    Solwise do some good ones and TP link are good. ..Clive
  15. The Following User Says Thank You to Clive S For This Useful Post:
  16. #120
    This did the trick , cheers Clive.
    my capacitor has a button on top . i couldn't find any info about it .maybe someone here might know.......... i fitted some of the switches ,and a temp control ( cheers Eddie). on the door of the panel and put some crude shelves up for the P.C. I had the fans fitted sucking air out on top .with vents to draw air in at the sides. i then came across a post so i think i'll be changing it about.http://www.mycncuk.com/threads/7831-...SURE+ENCLOSUREi got this in the post ( cheers again Eddie) so the power supply is next to be tackled . so if i mount the coil on a plate and the plate is earthed , will that not in turn earth the bolt holding the coil? will that be enough or will i have to earth the bolt also?
ID:	14801   Click image for larger version.
ID:	14802   Click image for larger version.
ID:	14803   Click image for larger version.
ID:	14804   Click image for larger version.
  1. NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
    By DarkWalkJRB in forum New Member Introductions
    Last Post: 07-02-2012, 08:31 PM
