Thread: Let the fun begin !!! ???
04-03-2015 #121There is no problem earthing the bolt with the plate. What you MUST NOT do is earth both ends of the bolt as this would present a shorted turn to the coil.so if i mount the coil on a plate and the plate is earthed , will that not in turn earth the bolt holding the coil? will that be enough or will i have to earth the bolt also
Regarding the button I have not seen one before are you sure it is not just a vent. Clive
04-03-2015 #122
maybe a vent as you said . i'll fire off an email to the supplier and see what comes back. cheers Clive
05-03-2015 #123
i'm in the process of building the power supply and would like to know if thermal compound is used on the base of the rectifier and on the base of the capacitor. i don't know if it's advisable to mount these without it. i had a look online for paste but keep getting paste for cpu's .
will this do?
05-03-2015 #124
06-03-2015 #125
i decided to test the coil with a power up so i used a safe block , hooked up the brown and blue to 230 vac i then joined black and yellow together and red and orange together on the secondary and put them in a terminal connector . when i engaged the safe block the coil hummed for about a second and then stopped. i checked the fuse in the safe block ( 13 amp ) and it was blown so i tried again and the same thing happened. i metered the connector and obviously got no reading . am i correct in thinking that i should not have blown the fuse and should have 50v ac across the terminals?
06-03-2015 #126
Do you have a link for the coil?
You need to connect the two sec. coils in series so join red and yellow and measure black and orange 50V It might well blow the fuse on start up with a 625w coil
..CliveLast edited by Clive S; 06-03-2015 at 05:17 PM.
06-03-2015 #127
http://www.airlinktransformers.com/c...nge/CM0625225/
just my luck to blow fuses. i thought i might have connected it wrong or perhaps i shouldn't have tested in in the manner in which i did. should i wait to get the rest of the supply hooked up or would that matter?Last edited by PAULRO; 06-03-2015 at 05:33 PM.
06-03-2015 #128
06-03-2015 #129
cheers Clive , 52.1 beautiful V ac.
12-03-2015 #130
finally got back to the power supply and got it set up . i'm reading 73 V DC . is this o.k. ? i know that 68 v dc is the magic number . is there a way to reduce it other than reducing the number of windings. i would not be comfortable with stripping out the coil to achieve that.
There are currently 31 users browsing this thread. (0 members and 31 guests)
NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
By DarkWalkJRB in forum New Member IntroductionsReplies: 2Last Post: 07-02-2012, 08:31 PM
