Thread: Let the fun begin !!! ???
Why is the rear plate so long.? you only need the rear plate long enough to fit bearings onto and give travel required. If your only wanting 160mm of movement then you would get away with shorter back plate and ballscrew.
Also one thing to take into account if your trying to get every last bit of travel out of screw is to allow for the bolt heads holding ballnut, you can easily loose 10mm depending on how tight you make it.
Regards the Z axis screw bearings then with screw being so short you don't really need one at the bottom if you want to keep cost down and it makes setting up that bit easier.
12-08-2014 #2
i had intended to use 20 mm rails on the z axis but after reading the various posts of your good self I am now going to use 15mm rails and guides to suit so i think a redesign is in order.
the rear plate should be shorter alright i just left it long enough to house the motor with a body of 100mm long and a plate to hold it.
i suppose the travel of the z axis could be longer but i went with that travel because of all the discussions about the length of the lever created by the extension. i suppose it's another trade off , keeping it to a minimum while having enough scope to machine to a reasonable depth. i'll get cracking at it again tomorrow, my shutters are starting to descend !
13-08-2014 #3
No I wouldn't. There's very little price difference between 15 & 20 and the bearing size and overall height makes building the z axis easier regards clearence for ballscrew. With 20mm you still need to machine a recess for the ball screw but it doesn't need to be so deep. With 15mm the recess is too deep so you end up having spacer blocks and this makes achieving accurecy that much harder.
In the past I've made Z axis for people who use 25mm rails just to get around having recess or spacer blocks thou I wouldn't take that route personally.
I've got 180mm on my Z axis and I rarely use more than 100mm and often it's much less than 80mm and most of this is for tool clearence not actual cutting depth so don't go chasing length as you'll probably never use it.
The fact you will have adjustable bed means you'll find a balance between Z extension and strength for the type of work your doing. This is the beauty of the movable bed you are very flexible and can always find the best height to suit the job IF NEEDED.!!! . . . I highlight these words becasue in practice you'll rarely move the bed (Because it's a pain in the arse resurfacing) but instead find that balance I've spoken off.
In normal DIY wood working every day use your very unlikely to use tools with over 100mm cutting length so I find 100mm is more than enough on a adjustable bed machine as I can always bring the work to the cutter if needed or create clearence by lowering bed.Last edited by JAZZCNC; 13-08-2014 at 08:13 AM.
13-08-2014 #4
i had used 20 mm flanged bearing blocks in the original dwg and that impacted on the clearance for the ball screwnut. I had also designed the z axis plate to be machined at 160 mm wide to try and keep the gantry length to the minimum . I should have used 20 mm square type bearing block to give more clearance and accommodate the 160mm width. ya i will stick with the z axis travel of 150mm - 160mm and adjustable bed. good call. i will have to get a supplier organized for the guides and rails. I dealt with chinese suppliers in a previous job and there were reliable so i'll drop them a line and see where it takes me. maybe i should wait until i have secured the rails and guides before I go any further with the z axis design?
13-08-2014 #5
Has anybody used the linear guides and rails from Chai? i have organised the ball screws from him and thought i would use his linear gear but only on a recommendation from the previous builders here.
13-08-2014 #6
19-08-2014 #7
steel has arrived and is cut and both sidewalls are welded.
I have to string the crossbeams and tie both together.
I contacted http://www.ecfibreglasssupplies.co.uk /to purchase epoxy 105 and hardener 209 but drew a blank . apparently they don't stock 209 hardener but told me the 205 or 206 hardener are very similar but for pot time and cure time. has anybody used these hardeners? i'll probably go with the 206 because it has a longer pot life but would like some feed back before i do.
i also spoke to Chai about his linear guides and rails and the preloads are as follows
Z1: 0-0.02C or Z2: 0.02C-0.05C . i'm sure either of these will do the job but would like to know which preload is the preferred choice for wood routers.
NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
By DarkWalkJRB in forum New Member IntroductionsReplies: 2Last Post: 07-02-2012, 08:31 PM
