Thread: Let the fun begin !!! ???
06-02-2015 #34
Well unfortunatly this happens but when shimmed they are fine. Looking at the shim I'm not quite sure your shimming the inner race or outer.?
If it's the inner then the bearings are in the wrong way around. You want them back to back with a shim between outer races.
Regards the Leadshine Closed loop steppers then they are nice but expensive. If your using Mach3 then just attaching encoders to your steppers won't help at all because Mach is not closed loop and all it can do is report the encoder position it cannot correct for error like the leadshine servo stepper drives do.
The closed loop stepper drives actually close the loop within the drive not in the control software so when you see it correcting position Mach doesn't know anything about it. Now this is good and bad at same time.?
It's good that the drive monitors position using the encoder and corrects for any error but at the same time if any error as happened it's still an error which causes a break in continuity between drive and control software. Because the loop is contained within the drive and never reports any small positional errors to mach then In affect Mach becomes in front of the drive for a short period before the position catches backup in that axis. Other axis will carry on in front So Depending on the error amount it can affect the job so the error still shows up in the finished job.!! . . . . . This is also true of servos or any other drive that doesn't have true closed loop system that works in tandem with the control software to sync axis together.
If the positional or what's called following error gets too great then the drive will fault and e-stop the system (which in affect is what Stall detect does but much cruder) This following error can be set in the drive parameters to a small amount so if goes outside parameters then drive faults and system E-stops.
This is how most servos work but like I say the small errors have still happened and at some point will show up in the work.!!
This is why you'll often see people who have experience with both Servos and steppers on slower machines like mills etc say that Servos are no more accurate than steppers if steppers are setup and tuned correctly.! . . . Error is Error and will show in the work with either system.!!
In some ways servo or Semi closed loop is worse than standard stepper system because you'll never know where the Error comes from as each axis have caught back up so when job finished all looks well and in position but the work piece still shows error. With steppers any lost steps can clearly be seen in the axis as it won't return back to where it started.!!
Servo's rule when heavy loads and high feeds are required Or when going point to point very fast like in positioning systems. For Small/Med routers or Small/Med mills steppers can match servos no problem without closed loop.Last edited by JAZZCNC; 06-02-2015 at 04:04 PM.
NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
By DarkWalkJRB in forum New Member IntroductionsReplies: 2Last Post: 07-02-2012, 08:31 PM
