Thread: Let the fun begin !!! ???
27-04-2015 #30
Ok well a good bit of caution is wise policy but you have no need to fear mach3 it won't do anything unless commanded too.
First thing to do make sure control box is wired correctly and all drives power up. Check the E-stop knocks the drives out when pressed.
When sure control side is ok then set about setting mach up.
First place to start after installing plug-ins etc for motion control card is in Ports n pins by setting any input pin numbers for Estop etc. Without these set Mach won't come out of reset. If want leave Homes and limits for later but E-stop will most likely need setting.
Next set the pin numbers for each motor in Motor Outputs. Then goto motor tuning and set the Steps per based on your Micro stepping setting and ballscrew pitch. Choose a low velocity and Accelleration for starters. 5000mm/min & 500s/s are good starting point.
You should now be ready to go for testing.
NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
By DarkWalkJRB in forum New Member IntroductionsReplies: 2Last Post: 07-02-2012, 08:31 PM
