Thread: Let the fun begin !!! ???
How did you toggle it with the active state or the Enable.?
The output Active state is not a Switch for toggling any thing On/OFF. It's a Logic condition that needs to be set so things can work correctly.
The enable is just that.!! . .Your turning the output off. So if the relay changes state then you probably have the Wrong Active Logic set and relay is coming on straight away and by disabling the Output it gets turned off.!
Set Active LO(unticked) and try M3/M5 again if relay doesn't change state(or Click) Set it HI(ticked) and try M3/M5 again.
Don't go Chopping and changing settings all over the place as it really makes finding faults difficult. Only make one change then Test.
26-05-2015 #2
i toggled the active state of the relays to see if mach3 could change the state of the relay from a non responsive state . i have them set back now to the folowing
the run relay 1 is on constantly because of active high setting. if i input M3 the spindle will run at 250-300rpm . M5 stops the spindle again. the only relay to change state is the PWM dependant relay 3
26-05-2015 #3
Paul your not listening properly because if you'd done as I suggested then the spindle wouldn't start at all. And the speed would be controlled from the VFD using what ever speed you set.
You need to take a few steps back and deal with one problem at a time. Stop changing settings willy nilly because this makes the Job of helping so much harder. All this does is waste yours and my time by chasing false issues. I need you to only change one thing at a time then report what happens.
First all you need to do is get Relay #1 working. Forget #2 & #3 we don't need them so you can turn them off on the BOB and disable them in Mach3.
Straight away I see that you have the Wrong Pin number set for Relay #1. It should be Pin 16 not 14.
Pin 14 is for the PWM Speed control which I believe is working fine just needs setting up for correct speeds which can be done later. NOT NOW.!!
So to re cap Tell me which terminals your connecting to on the Relay.
Set Output #1 = pin16 Active LO.
Turn off the Enable for Outputs #2, #3.
Next the relay will have 3 terminals which are you connecting to.?
26-05-2015 #4
i have relay 1( OUTPUT 1)
set to pin 16, active LO. ( ticked) ( all other relays disabled. )
TERMINALS on relay
N.O CONTACT =FOR on VFD
COMMON= DCM on VFDLast edited by PAULRO; 26-05-2015 at 08:28 PM.
26-05-2015 #5
RELAY 1 is on . i metered accross the N.O contact and common and have continuity.
26-05-2015 #6
26-05-2015 #7
that's O.K. Relay turns on/off using M3/M5. i had to change active lo setting to set it correct way .
26-05-2015 #8
On the side topic of pumps - I use a similar Whale pump. I use 12V to run it for a few seconds to purge bubbles more quickly, but I then run it on 5V. Seems to circulate enough water to keep the spindle cool, and I have run it like that for quite a few 5-6hr sessions continuously with no apparent ill effects.
Good luck with the Mach3/BOB issues!
02-06-2015 #9
hi Neale, how do you control the 12 volt psu dropping out and the 5 volt kicking in?
NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
By DarkWalkJRB in forum New Member IntroductionsReplies: 2Last Post: 07-02-2012, 08:31 PM
