Thread: Let the fun begin !!! ???
12-02-2015 #81
yeah , what was i thinking? my record has 1 to many scratches!
12-02-2015 #82Spelling mistakes are not intentional, I only seem to see them some time after I've posted
The Following User Says Thank You to EddyCurrent For This Useful Post:
12-02-2015 #83
12-02-2015 #84
cheers for the link Eddie. i was just about to press the go button on this http://ie.rs-online.com/web/p/alumin...itors/0497596/ . i can get the bridge there alsohttp://www.rapidonline.com/electroni...-mb352-47-3226
12-02-2015 #85
13-02-2015 #86
I would prefer to buy the drivers at Zapp but they have only 1 in stock. i phoned Gary but couldn't get through so i emailed him. Apparently the AM882 are discontinued and replaced with the EM806 which is'' the same or better specification as the AM8802 but a newer product'' . any thoughts on this would be helpful .
this is the psu coil Standard Range Toroidal Transformers- CM0750225- 750VA 230v to 2x25v delivery next friday 20th.
capacitor http---www.rapidonline.com-electroni...apacit-50-4017
bridge rectiferKbpc3502 35a 200v Bridge Rect (mb352) - Rapid Online.Last edited by PAULRO; 13-02-2015 at 02:32 PM.
13-02-2015 #87
13-02-2015 #88
13-02-2015 #89
cheers for the driver info. i had calculated for 5 motors even though i will only use 4 for the time being . the 5 will draw 13.2 amps @70 vdc hence the 750 VA.
The 625 VA delivers 11.90 amps. i hope my calcs are correct! is there a way around the in rush of current?
13-02-2015 #90
Yes Don't turn it ON. . .
You can build an inrush circuit using resistors, thermisters etc but I prefer to avoid this and use smallest transformer possible and then use a C or D rated fuse if still trips which I rarely do upto 625va. Can use slow blow fuses as well.
To be honest I very much doubt you'll ever run 5 Motors at same time that pull full amps at same time so I'd still go with 625Va and 12A.
NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
By DarkWalkJRB in forum New Member IntroductionsReplies: 2Last Post: 07-02-2012, 08:31 PM
. So back to ebay or aliexpress if I need more. ..Clive
