    Yes this is normal for them to be taken out after testing. They used to leave them in and they often got snapped off in transit, ive had many come like this. If the body was scratched then I'd be suspicous.
    The settings Ant (shinobiwan) posted are still the same I believe.
  2. The Following User Says Thank You to JAZZCNC For This Useful Post:
  3. #2
    cheers Jazz , I didn't fancy getting into a paper trail with the supplier. the body looks fine , no evidence of a mounting bracket. i had a read of the manual and to be honest it would take another good couple of reads to filter out the stuff when compared to Ants post. i'll still need to go over it once i hook up the bob with spindle control. but at least i have enough info to get me testing the vfd with the spindle. thanks again.
    do i need an internet connection to set up the PLCM-E3 OR MACH 3? my garage is a blind spot for a decent signal.
  5. #4
    Quote Originally Posted by PAULRO View Post
    Not for Mach3 but for the PLCM you may need certain windows system programs like DotNet etc to install plug-in and driver etc, depends how upto date your windows is.?
  7. #5
    I think you just download the plugin to a usb stick then you can do it without a internet connection. You might be able to use some homeplug adaptors like these http://www.diy.com/departments/tp-li...150301200758:s
    Solwise do some good ones and TP link are good. ..Clive
  8. The Following User Says Thank You to Clive S For This Useful Post:
  9. #6
    This did the trick , cheers Clive.
    my capacitor has a button on top . i couldn't find any info about it .maybe someone here might know.......... i fitted some of the switches ,and a temp control ( cheers Eddie). on the door of the panel and put some crude shelves up for the P.C. I had the fans fitted sucking air out on top .with vents to draw air in at the sides. i then came across a post so i think i'll be changing it about.http://www.mycncuk.com/threads/7831-...SURE+ENCLOSUREi got this in the post ( cheers again Eddie) so the power supply is next to be tackled . so if i mount the coil on a plate and the plate is earthed , will that not in turn earth the bolt holding the coil? will that be enough or will i have to earth the bolt also?
ID:	14801   Click image for larger version.
ID:	14802   Click image for larger version.
ID:	14803   Click image for larger version.
ID:	14804   Click image for larger version.
  10. #7
    There is no problem earthing the bolt with the plate. What you MUST NOT do is earth both ends of the bolt as this would present a shorted turn to the coil.
    Regarding the button I have not seen one before are you sure it is not just a vent. Clive
  11. The Following User Says Thank You to Clive S For This Useful Post:
  12. #8
    maybe a vent as you said . i'll fire off an email to the supplier and see what comes back. cheers Clive
  1. NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
    By DarkWalkJRB in forum New Member Introductions
    Last Post: 07-02-2012, 08:31 PM
