Thread: Let the fun begin !!! ???
04-03-2015 #34
This did the trick , cheers Clive.
my capacitor has a button on top . i couldn't find any info about it .maybe someone here might know.......... i fitted some of the switches ,and a temp control ( cheers Eddie). on the door of the panel and put some crude shelves up for the P.C. I had the fans fitted sucking air out on top .with vents to draw air in at the sides. i then came across a post so i think i'll be changing it about.http://www.mycncuk.com/threads/7831-...SURE+ENCLOSUREi got this in the post ( cheers again Eddie) so the power supply is next to be tackled . so if i mount the coil on a plate and the plate is earthed , will that not in turn earth the bolt holding the coil? will that be enough or will i have to earth the bolt also?Last edited by PAULRO; 04-03-2015 at 01:08 PM. Reason: more info
NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
By DarkWalkJRB in forum New Member IntroductionsReplies: 2Last Post: 07-02-2012, 08:31 PM
