Thread: Let the fun begin !!! ???
my electronics won't be with me until monday / tuesday . i had an email stating they're in transit , i put some more bits on the back plate i had an old 5vdc power supply plug in type set a side for the motion control card . i couldn't get a din mounted supply locally and i didn't want to wait for ebay so i'll give this a try. i still have to change the fans around on the box i'll tackle that tomorrow . i hope!!!
13-03-2015 #2
Can I make a few suggestions.!!
I wouldn't locate the VFD and the PSU next to the BOB and Motion control card and drives. Both these are very noisey devices and they could introduce noise onto the signal wires.
Ideally you want them furthest away from any signal devices like BOB and Drives.
Personally i'd have PSU and VFD at top and Drives/BOB/Control at bottom with Connections/24V psu etc in between with separation.
15-03-2015 #3
I had to put a breaker into my main board to support the extra load for this cnc and i forgot to power down my p.c. so the end result was a p.c. with a blown power supply .
i had a spare one from another m/c but it had different connectors so i spent the morning cutting and pasting.... who needs it ? anyway i changed the panel around and put the noisy bits on top i have to put more fuse holders, terminals etc. in tomorrow.Last edited by PAULRO; 15-03-2015 at 03:36 PM.
25-03-2015 #4
i 'm just getting back into the build today and i have the electronics mounted on the back plate. i have a query regarding the fuses for the 70 V DC power supply. i have the fuses on the negative side of the supply , is that o.k. ?
25-03-2015 #5
25-03-2015 #6
cheers Clive , i have a 6A in there , i just for got to update the dwg.! i better change the fuses around .
26-03-2015 #7
O.K. state of play so far is that i have the back panel in the cabinet and i'm doing some electrical dwgs so i can at least give myself a fighting chance to get it right . i have a couple of queries before i go and start lashing in wires though. this is what i think i know from reading the posts , so i just need some nudging .
1......am i correct in saying that i need a separate input for the slave home switch?
2 .... i need a separate input for the rest of the home switches combined in series.
3... because i'm combining both limits and home into a single switch i must keep the e stop on a separate input.
4... i also need an input for feed / hold
5..... and an input for stop.
bring my total of inputs to 5 ( MAX. allowed)
i also have alarm terminals on my drive so i'm curious about how i can get these in to an input. i will post some drawings of my proposed electrics as soon as i'm finished.
NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
By DarkWalkJRB in forum New Member IntroductionsReplies: 2Last Post: 07-02-2012, 08:31 PM
