    i left the dip switch positions off on the BOB. to be honest i thought that i would get the basics hooked in .i have an e/stop , a home /limt and xyz home/limit hoooek up normally closed . i thought that these would get me up and running.
Name:	e stop to bob.jpg
    i haven't the overide wired up yet , i didn't think that would matter with regards to getting the motors to turn .
    Looks like you hadn't set enable output. (enable1) Thats why the motors won't turn because the drive enable is being turned off.
    Try this xml.
    Attached Files Attached Files
  6. #5
    sorry Jazz , do i just unzip this and put it back into mach 3?
  7. #6
    Quote Originally Posted by PAULRO View Post
    Yes unzip and replace the original.
  9. #7
    well that did the trick o.k Jazz. at least i have the motors turning which was a great milestone to reach. i have to play with it to day to get comfortable with the different noises and speeds . i thought i had a problem with having only 3 inputs available because i couldn't use input 10 or 11 .......... turned out that they only become available for use when the dedicated inputs on the bob are wired in!!! every day is a day for school!! cheers for that last night , by the way.
  10. #8
    Erm that sounds dodgy.!!! Lets just be clear for those dirty minded types.!. . . Last night wasn't pyhisical people. . .
    Glad your working now get on with making chips.. .
  11. The Following User Says Thank You to JAZZCNC For This Useful Post:
  1. NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
    By DarkWalkJRB in forum New Member Introductions
    Last Post: 07-02-2012, 08:31 PM
