  1. #28
    i thought i had it all sorted so i tried to calibrate spindle from '' FUNCTION CONFIG'' tab. but it now has a different issue / maybe the same one ........
    so i tried as suggested ... PD001=1, PD002=0 .. Result is spindle running at top speed with no control from F5, or the '' SPINDLE SETUP '' tab in ports 'n pins.
    the ''DISABLE SPINDLE RELAYS '' or the ''MOTOR CONTROL '' box cannot control it either. i can, however turn of the relays from the '' OUTPUT SIGNALS '' tab using the '' ACTIVE LOW'' or '' ENABLED'' option. so MACH3 can control the relays from here .
    what has me puzzled now is that i have used the'' MDI'' tab to input M3 S2000 and the spindle runs once i hit ''enter '' on the key board or the spindle CW F5 . the VFD shows a reading of 20,904 on its window but the DRO for the spindle speed does not change. the '' RPM '' value in MACH 3 has never updated since i got the spindle running . when i turn it off and on again '' Spindle CW F5'' button or F5 from the keyboard then the led on the BOB for the PWM controlled relay 3 comes on , but doesn't burn as brightly as the start / stop relay led. the spindle will begin to run at 280 RPM (VFD readout)
    if i then hit ''RESET '' on the spindle speed window the spindle turns on fully and the led for the ''PWM '' relay3 burns brightly. this really has me puzzled.
    RELAY 3 is controlled by LPT pin 14 dedicated for PWM. i cannot turn this relay off from the output tab in port & pins .
ID:	15420   Click image for larger version.
  1. NEW MEMBER: Hello everyone. Total newbie here. Where do I begin?
    By DarkWalkJRB in forum New Member Introductions
    Last Post: 07-02-2012, 08:31 PM
