  1. #34
    Where is that place? Did you fit it into the gantry between the beams or at the back in the middle of one of the gantry sides? cause that is where i would fit it.
    Sorry for the late reply. I had a serious hiccup with my computer but finally is up and running again. Also I have decided to wait with the laser cut until the linear motion components arrive as I would like to double check some of the measurements.
    Yes I had to mount it on the side of the gantry as otherwise the Z axes would hit the pulley as my Z axes travels from outer gantry side plate to outer side plate.
    At the moment I have all the axes designed so they can be geared 3:1 or 2:1 will decide on that later all I had to see at the moment is that in either case the belts wont be hitting any of the mounting screws.
ID:	13572   Click image for larger version.
  2. Replies: 0
    Last Post: 13-11-2013, 07:50 PM
  3. Spindle lock mechanism for 2.2kW china spindle
    By Jonathan in forum Generic Chinese Spindles
    Last Post: 13-08-2012, 08:39 PM
  4. WANTED: Spindle holder for 1.5kw Chinese spindle.
    By jcb121 in forum Items Wanted
    Last Post: 14-10-2011, 02:07 PM
  5. DIY Spindle - What type of bearings are best suited for a spindle.
    By 8iggles in forum Spindles & Drive Motors
    Last Post: 09-02-2011, 10:15 PM
