  1. #9
    Quote Originally Posted by embraced View Post
    What sort of motor are you using for the spindle?
    And how on earth does it achieve such a high power density?
    It's the same type of motor as I used here - permanent magnet synchronous motor (PMSM), with an outer rotor. The high power density partly stems from the magnets, which replace the rotor magnetising current in, for example, an induction motor, resulting in lower losses. There is more to it than that though - e.g. differences in cooling.
    This is how far I've got with rewinding the motor - two phases done, but I do have a low resistance from one phase to the stator, so I'll probably have to re-do that one and be more careful.
ID:	12661Click image for larger version.
    Cut out the motor mount for Z from 20mm thick aluminium yesterday:
ID:	12669Click image for larger version.
ID:	12670Click image for larger version.
ID:	12659Click image for larger version.
    This morning I cut the motor mounting plate for the spindle motor:
ID:	12657Click image for larger version.
    This is where it fits:
    The large pulley (60T) isn't all the way on the spindle shaft, but this shows the general idea. The spindle pulley is keyed and the motor pulley fixed using four grubscrews, which should be sufficient...more on that later.
ID:	12664Click image for larger version.
    The spindle pulley is much bigger than the original gear, so I had to mill a bit off the top cover to clear the pulley and belt:
ID:	12663Click image for larger version.
    Z-ballnut mount (again):
    I just need to make the Z-ballscrew bearing mounts, finish rewinding the motor and make the driver, decide if I need an encoder on the spindle and then I can continue with the ATC.
  1. Warco WM16 Mill - Conversion to AC motor with VFD
    Last Post: 10-02-2022, 07:41 PM
  2. X2 Mill motor Problem
    By A11an in forum Milling Machines, Builds & Conversions
    Last Post: 20-01-2022, 12:26 PM
  3. Replies: 2
  4. Help and Advice sought about new motor for my mill
    By alanb in forum Milling Machines, Builds & Conversions
    Last Post: 26-01-2012, 08:04 PM
  5. FOR SALE: Mini Mill spindle motor + controller etc
    By pjm in forum Items For Sale
    Last Post: 22-06-2010, 07:34 AM
