Fantastic build Johnathan, thanks for posting, always get very envious looking @ your projects.
Regards
Mike
03-01-2016 #2
Thanks Mike.
Today, I milled two slots!
4mm wide by 5mm deep slots in the steel strips shown in the previous post. The slots will have simple covers placed into them.
Next I've devised a bit of a mad scheme to drill the array of M6 holes in the bed:
Then checked that it was sufficiently parallel - couple of whacks with the nearest hammer and it's now within 0.05mm over 400mm.
Now to continue the drawing...
03-01-2016 #3
03-01-2016 #4
04-01-2016 #5
Ok, broken tap situation resolved...
I intend to buy the fasteners I need for this tomorrow, so time for some rough calculations to check what grade I should use. From the THK documentation, I gather that the tightening torques for the M8 and M6 fasteners in the rails should be 30.4Nm and 13.7Nm respectively. They don't recommend a grade of fastener (as far as I can see), so we are left to work out the tensile strength required ourselves.
First step, use the torque value to calculate the tensile force on the fastener. This is the same formula as working out the axial force you get for a given torque on a ballscrew, so I don't even need to look it up (although can be more accurate by including more in this):
This gives the force, for a given torque (tau), coefficent of friction (mu, ~0.2 for steel) and pitch. Machine screws are graded based on the tensile stress, so we need to divide this value of force by the cross sectional area of the screw to arrive at the stress, in N/mm^2. The stress area is roughly the minor diameter of the fastener, so roughly the diameter of drill you would use. The area is then clearly just the area of a circle.
So, e.g, the M6 fasteners are 1mm pitch, 13.7Nm and steel, so the force is 13.7*2*pi*0.2/0.001=17kN. Divide that by the stress area, 17000/(pi*2.5^2)=865Mpa. Bolts are graded such that the first number is 1/100th of their tensile strength rating, so e.g. a 10.9 grade fastener is rated for 10*100=1000Mpa. A rule of thumb suggests to only tighten a bolt to about 80% of its tensile strength rating, so in my case I will be OK with 10.9 grade fasteners for the M6 screws (especially as the actual stress for the given torque will be a bit less due to things I missed out for brevity).
Now I just need to remember to bring my torque wrench home...
Also noticed that RS have the caps to help prevent debris getting into the linear rails, so I'll get some of those.Last edited by Jonathan; 04-01-2016 at 02:24 AM.
The Following User Says Thank You to Jonathan For This Useful Post:
04-01-2016 #6
good to see your doing something at last!
if you need a lift with ought let me know. Although I about give myself a hernia the other week lifting the motor ontop of my mill.
matt
05-01-2016 #7
Today I almost finished tapping the bed and made some bits for other projects / people. That's about it ... will buy some steel flat bar I need tomorrow to finish off the bed.
Thanks for the offer, but what would be most helpful from you is if we could come to some arrangement whereby I get to use your new mill for a few hours? The XY carriage piece may be manageable on mine, but the bed piece is going to be too big.Last edited by Jonathan; 05-01-2016 at 12:36 AM.
Warco WM16 Mill - Conversion to AC motor with VFD
By birchy in forum Milling Machines, Builds & ConversionsReplies: 16Last Post: 10-02-2022, 07:41 PM -
X2 Mill motor Problem
By A11an in forum Milling Machines, Builds & ConversionsReplies: 18Last Post: 20-01-2022, 12:26 PM -
AC servo motor to replace a 3 phase induction motor on a mill spindle.
By rnr107 in forum Spindles & Drive MotorsReplies: 2Last Post: 23-04-2014, 03:14 PM -
Help and Advice sought about new motor for my mill
By alanb in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 26-01-2012, 08:04 PM -
FOR SALE: Mini Mill spindle motor + controller etc
By pjm in forum Items For SaleReplies: 1Last Post: 22-06-2010, 07:34 AM
