Thread: Y-Axis Designs
Jonathan is correct that "A" is technicly the better option but I've built machines with ballscrews in all locations, on front, up high and at rear and I've yet to see any significan't differance that makes me say don't use any of them. The only time I'd shy away from any of the others is if machine is going to cut hard and aggresively in hard materials.
I also don't agree that mounting profiled linear rails directly to extrusion is a bad thing provided the rail is wide enough and obviously profile is straight good HD quality. If done correctly then it can be very accurate and easy to use. I do this all the time and assure you it's accurate enough for any router type machine. If your wanting milling machine levels of strength and accuracy then your using the wrong material any way.!!
Open Source Dust Shoe Designs
By Tomnewry in forum Open Source Designs & PlansReplies: 22Last Post: 30-06-2014, 01:51 PM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
NEW MEMBER: Goal - Enable 3-Axis CNC Bed Mill to Perform 5-Axis Milling
By LoveLearn in forum New Member IntroductionsReplies: 2Last Post: 25-01-2012, 08:46 PM -
Y axis is making X axis stall...!!
By fasteddy in forum Machine DiscussionReplies: 83Last Post: 24-10-2011, 12:19 PM -
Precision metal processing (3 axis, 5 axis, 7 axis) OEM
By 7AxisCNC in forum Manufacturer NewsReplies: 0Last Post: 17-05-2011, 02:04 PM
