27-06-2014 #11
He’s talking in terms of adding strength to the machine and he’s right but I was really referring to eliminating resonance more than anything, I can’t see that adding ribs/reinforcing plates wouldn’t add extra strength to the column, I think they would help towards stopping any twist in the column at the very least.
I think the problem with concrete is that it’s relatively brittle (though I note your suggestion of using rebar), cracks could form in the concrete and over time it may break down inside the column, I don’t know enough but I’m guessing that it doesn’t really have the same dampening properties as other materials, epoxy resin is a favourite but so is kiln dried sand and the sand is cheaper in comparison.
I think what I will do with mine is to, reinforce the column on the inside, use a mix of aggregate (different sizes, type 2, pea shingle and so on) to then fill the column, then backfill the lot with epoxy resin (filling up the leftover voids) all the way to the top, hopefully creating one solid mass. The idea being the aggregate is just away to use less resin (cost vs. cost) but also brings back the properties of using sand.
.MeLee
WANTED: cnc milling machine
By bigred5765 in forum Items WantedReplies: 14Last Post: 25-04-2014, 11:08 PM -
WANTED: X3 CNC milling machine
By Nemo1966 in forum Items WantedReplies: 1Last Post: 09-11-2013, 10:42 PM -
WANTED: Milling machine head
By Ainis in forum Items WantedReplies: 0Last Post: 23-07-2013, 09:30 PM -
New CNC Controller for Milling Machine
By antsals in forum Electronic Project BuildingReplies: 26Last Post: 08-04-2012, 06:09 PM -
First CNC milling machine help
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 05-09-2011, 10:06 PM
