11-01-2015 #61
Finally after waiting for a few parts in the post, limit switch and oil lines are all in place, y axis is complete, now for the x
The Following User Says Thank You to totts For This Useful Post:
11-01-2015 #62
Some of you may have noticed the m8 holes are close to the edge on the ball nut holder, unfortunately the dimensions i was given for the limit switch were wrong and i had to change the size to get it to fit. Grrr
12-01-2015 #63
Well done. This site shows just what super work some people are able to produce. That is looking great. G.
12-01-2015 #64
first time ive seen this thread; just read with much interest. looking forward to the updates
12-01-2015 #65
i like it, what are you using to drive the oil down the tubes ?
12-01-2015 #66
A couple of ideas, one is to either attach them onto a manifold with individual grease nipples, or attach them to an oil resivoir and attach a valve to presurise it to push the oil through.
13-01-2015 #67
I obtained small 220V pump from an iron or steam cleaner, not sure. Payed 2 euro on a boot sale. Similar to the ones used in cars, that throw water on the front glass. However i prefer the 220V version cause no messing with transformers and so plus it vibrates instead of rotates, so pumps slowly, exactly what we need. The one i have is something similar to this one , checked it with oil and it works. Believe the flow is adequate for the purpose.
13-01-2015 #68
13-01-2015 #69
13-01-2015 #70
Getting cold in the garage ! :( need to make more bits now as ive nearly ran out of things to put together :s
Beds on now yay! Hopefully there to stay!
And some more oil feed lines
WANTED: cnc milling machine
By bigred5765 in forum Items WantedReplies: 14Last Post: 25-04-2014, 11:08 PM -
WANTED: X3 CNC milling machine
By Nemo1966 in forum Items WantedReplies: 1Last Post: 09-11-2013, 10:42 PM -
WANTED: Milling machine head
By Ainis in forum Items WantedReplies: 0Last Post: 23-07-2013, 09:30 PM -
New CNC Controller for Milling Machine
By antsals in forum Electronic Project BuildingReplies: 26Last Post: 08-04-2012, 06:09 PM -
First CNC milling machine help
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 05-09-2011, 10:06 PM
