30-06-2014 #21
its an impressive build so far totts,wheres the adjustable gas strut from and whats it rated at?thanks
30-06-2014 #22
http://www.strutsdirect.co.uk/produc...-sd03-400-p-76
Their postage is a little high but not to badly priced.
They come in many lengths n sizes, mines adjustable set at 1200N but will release the pressure when everything is assembled.Last edited by totts; 30-06-2014 at 10:10 PM.
30-06-2014 #23
not bad at all,thanks a lot,
keen to see this mill in action.,i did toy with making my own for a while then bottled it and bought an sx3.Last edited by dazza; 30-06-2014 at 10:32 PM.
30-06-2014 #24
Yeah i came very close to getting an sx3, axminster had a 10% off all machines, and when i went on the website they had been reduced due to discontinuing them, and could have picked a new one up for £800!
Only thing that stopped me is the need for a slightly bigger travel and higher spindle speeds.
Have you a video of your sx3 in action?Last edited by totts; 30-06-2014 at 10:50 PM.
30-06-2014 #25
no not yet I bought it new from arc a while back and immediately ripped it aprt and fitted ball screws and steppers.(wishing I put profile rail on it after seeing what you and jonathan are upto..upgrade for the future maybe)at the minute im on the wiring so a week or two away yet.
30-06-2014 #26
Will be very interested to see it running! Yeah profile rail is bloody exspensive tho :(
02-07-2014 #27
Got some steel strips made up now ready to be bolted onto the bed, just waiting for some stainless steel countersunk screws to turn up!
02-07-2014 #28
I would be very carfull filling anything like that with that much epoxy and when it cures it can produce a huge amount of heat and contained in a metal tube you could have a small disaster on your hands. If you do want to do this make sure it is extremely slow curing and if anything put some bags of ice around it to keep the heat down and only do a little at a time.
The Following User Says Thank You to charlieuk For This Useful Post:
02-07-2014 #29
02-07-2014 #30
depends exactly on the epoxy but yes especially in warm temps, if you left a cup of epoxy to cure on its own you would be surprised how much smoke it can make! its a exothermic reaction so when if heat starts to build its a chain reaction and just gets hotter and hotter and will quickly turn into a smoking and bubbling mess. Ive never had flames but have heard of it. It all so doesn't make any different if you have some sort of filler mixed in with the epoxy so less actual resin to fill the space it will still have the same effect. As i said small quantities a bit at a time in a cold temp is your safest bet.
WANTED: cnc milling machine
By bigred5765 in forum Items WantedReplies: 14Last Post: 25-04-2014, 11:08 PM -
WANTED: X3 CNC milling machine
By Nemo1966 in forum Items WantedReplies: 1Last Post: 09-11-2013, 10:42 PM -
WANTED: Milling machine head
By Ainis in forum Items WantedReplies: 0Last Post: 23-07-2013, 09:30 PM -
New CNC Controller for Milling Machine
By antsals in forum Electronic Project BuildingReplies: 26Last Post: 08-04-2012, 06:09 PM -
First CNC milling machine help
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 05-09-2011, 10:06 PM
