Page 11 of 16 FirstFirst ... 910111213 ... LastLast
  1. What are the 5 grey looking things in the middle Si ?
    Good to see your still pushing on with it all :)
    .Me
    They look like solid state relays
  3. #103
    U guessed correctly! :)
    Simon
  4. #104
    I messed around for a while with those for my control box but in the end I could not get them to do what I wanted. I think I was trying to use them to switch the main toroidal power supply using a DC circuit or something like that.
    I used a contactor in the end which works a treat and is the right thing for the job. Why so many and what are they switching?
    By the way, loving the machine so far.
  5. #105
    Thats what i wanted, using them with my 24v psu to switch on the toroidal ps, spindle, cooling, estop, program estop and coolant. Using the 24v for switching. I hope it all works lol
    Simon
  6. #106
    Solid state relays are not always good thing to use because they often fail ON.!
  7. #107
    Yeh ive heard that, the electricians in work have told me a few stories, which im surprised the fail on, i have two relays operating on the estop so i hope thats enough otherwise i will go back to normal relays.
    Simon
  8. #108
    Please only use normal relays or contactors for e-stop, SSR's are really only safe for loads like heaters and lamps, i learnt this years ago when i was doing R&D for printing process and finishing machinery. They fail regularly and 99% will fail ON not off. Even when used for heaters you need to use sensors for over-heat which happens when they fail.
    If using for motors, always fit a good snubber network to help protect the SSR.
    Loving the build BTW;)
  9. #109
    Morning all, managed to get it up and running and wondering if anyone can give me some electrical advice,
    I'm currently using an akz250 (usb Bob) no I know that u need a stable 5v to run? Also using dq860ma steeper drivers.
    The problem is when I run a long program like the one in the picture, I loose steps in the x axis, one roughing cut depth is different to the next.
    Now I've tried slowing the motors down and changing the acc, and the problem still happens.
    I had a quick look at my wiring and ran a multi meter over the terminals, I have 4.45v going to (can't remember if it was step/dir) and 2.7v on the other terminal,
    Also my drive has an enbl + / - terminal, do I need to wire 5v signal to this? As my drive is working without it?
  10. #110
  11. The Following User Says Thank You to totts For This Useful Post:
  1. WANTED: cnc milling machine
    By bigred5765 in forum Items Wanted
    Last Post: 25-04-2014, 11:08 PM
  2. WANTED: X3 CNC milling machine
    By Nemo1966 in forum Items Wanted
    Last Post: 09-11-2013, 10:42 PM
  3. WANTED: Milling machine head
    By Ainis in forum Items Wanted
    Last Post: 23-07-2013, 09:30 PM
  4. New CNC Controller for Milling Machine
    By antsals in forum Electronic Project Building
    Last Post: 08-04-2012, 06:09 PM
  5. First CNC milling machine help
    By newtoid1986 in forum Milling Machines, Builds & Conversions
    Last Post: 05-09-2011, 10:06 PM
