17-03-2016 #101
What are the 5 grey looking things in the middle Si ?
Good to see your still pushing on with it all :)
.MeLee
17-03-2016 #102
They look like solid state relays
17-03-2016 #103
17-03-2016 #104
I messed around for a while with those for my control box but in the end I could not get them to do what I wanted. I think I was trying to use them to switch the main toroidal power supply using a DC circuit or something like that.
I used a contactor in the end which works a treat and is the right thing for the job. Why so many and what are they switching?
By the way, loving the machine so far.
17-03-2016 #105
Thats what i wanted, using them with my 24v psu to switch on the toroidal ps, spindle, cooling, estop, program estop and coolant. Using the 24v for switching. I hope it all works lol
Simon
17-03-2016 #106
Solid state relays are not always good thing to use because they often fail ON.!
17-03-2016 #107
Yeh ive heard that, the electricians in work have told me a few stories, which im surprised the fail on, i have two relays operating on the estop so i hope thats enough otherwise i will go back to normal relays.
Simon
18-03-2016 #108
Please only use normal relays or contactors for e-stop, SSR's are really only safe for loads like heaters and lamps, i learnt this years ago when i was doing R&D for printing process and finishing machinery. They fail regularly and 99% will fail ON not off. Even when used for heaters you need to use sensors for over-heat which happens when they fail.
If using for motors, always fit a good snubber network to help protect the SSR.
Loving the build BTW;)
17-08-2016 #109
Morning all, managed to get it up and running and wondering if anyone can give me some electrical advice,
I'm currently using an akz250 (usb Bob) no I know that u need a stable 5v to run? Also using dq860ma steeper drivers.
The problem is when I run a long program like the one in the picture, I loose steps in the x axis, one roughing cut depth is different to the next.
Now I've tried slowing the motors down and changing the acc, and the problem still happens.
I had a quick look at my wiring and ran a multi meter over the terminals, I have 4.45v going to (can't remember if it was step/dir) and 2.7v on the other terminal,
Also my drive has an enbl + / - terminal, do I need to wire 5v signal to this? As my drive is working without it?
17-08-2016 #110
The Following User Says Thank You to totts For This Useful Post:
WANTED: cnc milling machine
By bigred5765 in forum Items WantedReplies: 14Last Post: 25-04-2014, 11:08 PM -
WANTED: X3 CNC milling machine
By Nemo1966 in forum Items WantedReplies: 1Last Post: 09-11-2013, 10:42 PM -
WANTED: Milling machine head
By Ainis in forum Items WantedReplies: 0Last Post: 23-07-2013, 09:30 PM -
New CNC Controller for Milling Machine
By antsals in forum Electronic Project BuildingReplies: 26Last Post: 08-04-2012, 06:09 PM -
First CNC milling machine help
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 05-09-2011, 10:06 PM
