Page 12 of 16 FirstFirst ... 21011121314 ... LastLast
  1. #111
    Lives in Marple Stockport, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,345. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Nice to see you have it up and running. I don't know anything about that board but are you powering it via the USB if so can you power it from a separate power supply?
    Are you running the drives at about 68V?
    You don't need to connect to the enable terminal, that won't effect missing steps etc.
  2. #112
    Possibly due to the Step pulse being on the wrong side of the slope. Commonlly step pulse is on the rising edge but in some cases drives may be set so on the Falling edge. If this is the case and on wrong side then can lose one step with every direction change.
    To check this write program that goes back n forth few hundred times on that axis. Mark the start point and check it goes back to same point after the moves.
    If doesn't then change the Step low active in Motor Outputs. This will put the Step pulse on the opposite edge.
  3. #113
    It's a 70v psu I can't remember the exact voltage from the psu,
    The akz250 is a Chinese board . I m pretty sure I can wire a different supply to it by using this diagram -
  4. #114
    This would make sense as the toolpaths have a lot of direction changes due to it being an adaptive toolpaths, so if I change step low active will this run the motor in the opposite direction?
  5. #115
    Quote Originally Posted by totts View Post
    No it shouldn't but if it does then just go into Homing and Limits and select Reverse. You may need to change the Home direction.
    Don't Change the Dir Active leave that the same as it can have an affect on drive.
    However Like I said wouldn't change it without knowing for sure and the only way is to mark and run test code.
  6. #116
    Thanks will get some code running on it when I can get to it next and set up a dti hope this works!
  7. #117
    Okay so I ran 1000 lines of code from the settings I'm on and It went back to zero, I changed the step active and same code no missed steps.
    I then ran my code that I've been having trouble with, about 4000 lines and I didn't have no missed steps, but I have this new problem when I jog my machine it Judders whichever settings I use and at whatever speed, but when I run a program it doesn't judder , weird huh?
    Video -
  8. #118
    P.s I know it's stalling it does it even if I change the acc and speed. It does it in every axis
  9. #119
    had loads of problems with keyboards so try different keyboard before anything else
  10. #120
    I've used a pendant and a keyboard same problem :(
  1. WANTED: cnc milling machine
    By bigred5765 in forum Items Wanted
    Last Post: 25-04-2014, 11:08 PM
  2. WANTED: X3 CNC milling machine
    By Nemo1966 in forum Items Wanted
    Last Post: 09-11-2013, 10:42 PM
  3. WANTED: Milling machine head
    By Ainis in forum Items Wanted
    Last Post: 23-07-2013, 09:30 PM
  4. New CNC Controller for Milling Machine
    By antsals in forum Electronic Project Building
    Last Post: 08-04-2012, 06:09 PM
  5. First CNC milling machine help
    By newtoid1986 in forum Milling Machines, Builds & Conversions
    Last Post: 05-09-2011, 10:06 PM
