    Good start - almost getting jealous!
    Correct me if I'm wrong, but it looks like you're leaving the back of the Z column open, so it's a C-shape section not a box? If so then you should defiantly put another plate on the back, as the torsional stiffness of a C-section is very low compared to a box. That's one of the big advantages of putting the ballscrew on the front of the column, not inside - you can have a closed section.
    Dito!, Jonathan if he was to close the back up and opt for a box, would it be of worth while benefit to also add some ribs inside the box, I was thinking towards cantilever, an X in a square, the through sections on each plate would also allow then for the filling of the column?
    Quote Originally Posted by totts View Post
    I have a nice solid slab of aluminium as shown in the drawing, about 500mm x700mm by 76mm thick so i hope this will be solid enough.
    I was going to fit some of the electronics into the colomn but i am now going to make a stand to house the spindle cooler, electronics, pc and coolant pump, so will probably think about filling the column with something after the z stepper and y stepper is mounted so i know where to fill.
    Trouble is the cost keeps mounting up :( best not to take note and hide the reciepts from the missus hahah
    Sounds like it would be.
    I think its fair to say that making it a box and filling it would be of more benefit to the machine.
    Hehe, what's new .
    .Me
  1. WANTED: cnc milling machine
    By bigred5765 in forum Items Wanted
    Last Post: 25-04-2014, 11:08 PM
  2. WANTED: X3 CNC milling machine
    By Nemo1966 in forum Items Wanted
    Last Post: 09-11-2013, 10:42 PM
  3. WANTED: Milling machine head
    By Ainis in forum Items Wanted
    Last Post: 23-07-2013, 09:30 PM
  4. New CNC Controller for Milling Machine
    By antsals in forum Electronic Project Building
    Last Post: 08-04-2012, 06:09 PM
  5. First CNC milling machine help
    By newtoid1986 in forum Milling Machines, Builds & Conversions
    Last Post: 05-09-2011, 10:06 PM
