02-07-2014 #11
depends exactly on the epoxy but yes especially in warm temps, if you left a cup of epoxy to cure on its own you would be surprised how much smoke it can make! its a exothermic reaction so when if heat starts to build its a chain reaction and just gets hotter and hotter and will quickly turn into a smoking and bubbling mess. Ive never had flames but have heard of it. It all so doesn't make any different if you have some sort of filler mixed in with the epoxy so less actual resin to fill the space it will still have the same effect. As i said small quantities a bit at a time in a cold temp is your safest bet.
The Following User Says Thank You to charlieuk For This Useful Post:
WANTED: cnc milling machine
By bigred5765 in forum Items WantedReplies: 14Last Post: 25-04-2014, 11:08 PM -
WANTED: X3 CNC milling machine
By Nemo1966 in forum Items WantedReplies: 1Last Post: 09-11-2013, 10:42 PM -
WANTED: Milling machine head
By Ainis in forum Items WantedReplies: 0Last Post: 23-07-2013, 09:30 PM -
New CNC Controller for Milling Machine
By antsals in forum Electronic Project BuildingReplies: 26Last Post: 08-04-2012, 06:09 PM -
First CNC milling machine help
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 05-09-2011, 10:06 PM
