    A couple of ideas, one is to either attach them onto a manifold with individual grease nipples, or attach them to an oil resivoir and attach a valve to presurise it to push the oil through.
    I obtained small 220V pump from an iron or steam cleaner, not sure. Payed 2 euro on a boot sale. Similar to the ones used in cars, that throw water on the front glass. However i prefer the 220V version cause no messing with transformers and so plus it vibrates instead of rotates, so pumps slowly, exactly what we need. The one i have is something similar to this one , checked it with oil and it works. Believe the flow is adequate for the purpose.
    [QUOTE=silyavski;65874Believe the flow is adequate for the purpose.[/QUOTE]
    Are you sure the pressure output is sufficient?
    Not sure. But pressure for what? it just has to move the oil down, hence slightly help the gravity. Oil, not grease. Your oil system has pressure?
  1. WANTED: cnc milling machine
    By bigred5765 in forum Items Wanted
    Last Post: 25-04-2014, 11:08 PM
  2. WANTED: X3 CNC milling machine
    By Nemo1966 in forum Items Wanted
    Last Post: 09-11-2013, 10:42 PM
  3. WANTED: Milling machine head
    By Ainis in forum Items Wanted
    Last Post: 23-07-2013, 09:30 PM
  4. New CNC Controller for Milling Machine
    By antsals in forum Electronic Project Building
    Last Post: 08-04-2012, 06:09 PM
  5. First CNC milling machine help
    By newtoid1986 in forum Milling Machines, Builds & Conversions
    Last Post: 05-09-2011, 10:06 PM
