    Quote Originally Posted by totts View Post
    This would make sense as the toolpaths have a lot of direction changes due to it being an adaptive toolpaths, so if I change step low active will this run the motor in the opposite direction?
    No it shouldn't but if it does then just go into Homing and Limits and select Reverse. You may need to change the Home direction.
    Don't Change the Dir Active leave that the same as it can have an affect on drive.
    However Like I said wouldn't change it without knowing for sure and the only way is to mark and run test code.
  1. WANTED: cnc milling machine
    By bigred5765 in forum Items Wanted
    Last Post: 25-04-2014, 11:08 PM
  2. WANTED: X3 CNC milling machine
    By Nemo1966 in forum Items Wanted
    Last Post: 09-11-2013, 10:42 PM
  3. WANTED: Milling machine head
    By Ainis in forum Items Wanted
    Last Post: 23-07-2013, 09:30 PM
  4. New CNC Controller for Milling Machine
    By antsals in forum Electronic Project Building
    Last Post: 08-04-2012, 06:09 PM
  5. First CNC milling machine help
    By newtoid1986 in forum Milling Machines, Builds & Conversions
    Last Post: 05-09-2011, 10:06 PM
