23-08-2016 #18
So you have no stalling at full speed? Run this a 1000 times:
G00X(maximum X)
G00X(minimum X)
...to check X and likewise for Y and Z separately to check stalling. Running as short as to 10 units (inches or mm?) can be too short to test for stalling, but it is enough if missing/extra steps are needed to be checked. Also it is better to separately test the axes because running all three at the same time may result in less speed per axis than the maximum.Last edited by A_Camera; 23-08-2016 at 12:02 PM.
WANTED: cnc milling machine
By bigred5765 in forum Items WantedReplies: 14Last Post: 25-04-2014, 11:08 PM -
WANTED: X3 CNC milling machine
By Nemo1966 in forum Items WantedReplies: 1Last Post: 09-11-2013, 10:42 PM -
WANTED: Milling machine head
By Ainis in forum Items WantedReplies: 0Last Post: 23-07-2013, 09:30 PM -
New CNC Controller for Milling Machine
By antsals in forum Electronic Project BuildingReplies: 26Last Post: 08-04-2012, 06:09 PM -
First CNC milling machine help
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 05-09-2011, 10:06 PM
