I would think it will be ABS Silyavski, thanks for the link i've added it to my ebay watching list, I was thinking that a nice sharp+hard cutter (carbide) would be better but didnt even think about the helix, thanks for the tip!
.MeLee
26-06-2014 #2
All the bits i use are only Kyocera bits from him, unbeatable price quality. Funny that they are the cheapest around. The seller is fast and packet comes for 5 days to Spain from USA.
Now back on the plastic. I posted it before, so just dug it out. I dont know what is your machine . Mine is very flimsy. So these should work 100% on any machine. Treat ABS as Plexiglas.
Plastic likes sharp bits.
Depth of cut is crucial for melting the plastic. You can just use the suggested speeds and speeds slowly raising the depth of cut until you are happy.
Everything in imperial,1/8 or 1/4 it doesn't matter as usually the machine is the limiting factor here , not the bit , though more careful with longer or thinner bits :
soft plastic , its scratching but if you go deeper with flimsy machine, it melts.
Attachment 10779
plexiglass
Attachment 10780
MDF,wood, works for phenolic plastic also, composite panel
Attachment 10783
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
27-06-2014 #3
These are excellent resources for me, thank you!
Once the bit is delivered I'll run it with the correct parameters and see how it goes.
Thank you both very much!
How to get this finish..?
By Wal in forum Metal Finishing TechniquesReplies: 15Last Post: 02-02-2017, 11:08 PM -
Diy 4th axis rotary table using 100mm chuck with minimal backlash
By kingcreaky in forum Linear & Rotary MotionReplies: 3Last Post: 05-09-2013, 01:03 PM -
zero or minimal runout - shaft part
By dsc in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 06-12-2012, 03:09 PM -
Better finish
By luke11cnc in forum Wood Finishing Tips & TricksReplies: 20Last Post: 27-03-2012, 11:25 PM -
Need advice on surface finish
By FatFreddie in forum Machine DiscussionReplies: 4Last Post: 01-05-2010, 02:51 PM
