    Welcome to the forum!
    1. Normally you would design your part in a Cad/cam package, then load the gcode from the cam package to the machine package, so mach3 (windows) LinuxCNC (linux).
    2. In this instance the gcode would be your machine code, as that is what your machine control software (machine package) reads/proccess (mach3 or LinuxCNC).
    3. He has the choice really, see above.
    4. I would go with a windows supported cad/cam package then, again mach3 may be the better choice on the host machine as well.
    .Me
    Hi Lee
    Thanks for your reply. I think the issue is that the PC supplied by Sherline has built-in drives for the CNC lathe's motors. Something like this:
    http://www.sherline.com/8540pg.htm
    (although he has a lathe not a mill).
    So I guess he really is tied to a Linux environment - unless he can develop g-code on Windows and copy it to Linux for running on the Lathe.
    David
    Lives in Plymouth, United Kingdom. Last Activity: 5 Hours Ago Has a total post count of 1,747. Received thanks 298 times, giving thanks to others 11 times.
    I think that he already has LinuxCNC, although the web site refers to it under its old name, EMC2. Same thing but name changed due to trademark or some such issue a while ago.
    You can develop gcode wherever you like. You can hand-write it, but most people use some kind of CAM package that takes a CAD drawing as input and gives gcode as output. It can be a bit more complicated than that, but that is the basic principle. As Lee says, your friend would then run LinuxCNC which takes the gcode file and turns it into actual motor control signals. Because the gcode is portable (pretty standard with minor variations depending on whether LinuxCNC or Mach3 or some other machine control package will read it - you tell the CAM package which flavour of gcode you want) then you don't have to run CAD or CAM or machine control on the same platform. Mix and match as you will. I use Windows for CAD and CAM but copy files over the network to my LinuxCNC/Ubuntu machine in the garage. That kind of thing is pretty standard practice.
    That's a pretty high-level description. Someone will be able to fill in details if you would like to go down a level or two.
  4. The Following User Says Thank You to Neale For This Useful Post:
  1. Hobby-CNC Workflow - SKETCHUP + CAMBAM + MACH3
    By WandrinAndy in forum Computer Software
    Last Post: 04-10-2013, 02:53 PM
  2. Newbie - Questions about converting lathe
    By loply in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 05-09-2013, 08:30 PM
  3. NEW MEMBER: Newbie questions
    By peterl in forum New Member Introductions
    Last Post: 09-05-2013, 11:45 PM
  4. Replies: 2
  5. NEW MEMBER: Hi guys! Newbie here. Silly questions coming up
    By Simon in forum New Member Introductions
    Last Post: 26-06-2011, 10:02 AM
