Thread: MDF and alu sandwich router
01-01-2010 #41
Mainly for my benefit - a few EMC2 file backups (v2.3.4).
If they're not useful to you they will be to me if my PC every fries itself!!!(Thanks for the diskspace Lee!
If anyone uses these just be careful - I'm learning so there could be some mistakes in here I haven't found yet...
Change summary:
Custom HAL File - startup of classicladder for touchprobe. Startup of chargepump.
Custom PostGUI HAL File - connects AXIS PyVCP buttons (jog, touchprobe, and various easy homing and co-ord change buttons)
Main HAL File - not sure if there any changes here - maybe the charge pump one.
Custompanel.xml - pyVCP button layout (as PostGUI HAL file)
Classicladder File - sorts out the logic and debouncing of the touchprobe (allows single button touchoff)
Main INI File - Base & Servo periods, scales for axes (X needs tweaking), homing, limits. MDI commands for touchoff and other PyVCP buttons.
01-08-2010 #42
I finally got around to replacing the dodgy original MDF router mount with a shiny "John S" type. An evening with an alu block and a mini-lathe is all it took.
It has (obviously) massively improved the quality of cutting, and I can just just just cut aluminium now. Though 0.3mm depth of cut doesn't really count as cutting. Closer to vigorous polishing, but it's progress.Well chuffed.
Off to post a separate Q about dust extraction now....
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM
