Thread: MDF and alu sandwich router
22-05-2009 #11
OK, a bit more progress this week... And the result is a rolling X axis!! wooo hoooo!!
My Y gantry was ready to go, so this week I drilled the X rails (8mm dia), clamped them to the router bed and adjusted to get things roughly symmetrical. When happy, I put 8mm holes through the router bed itself.
Next I removed the rails and opened the holes out to 12mm dia - this is part of my 'cunning plan' to allow things to be set up just right when it comes to final assembly. The oversize holes allow up to 2mm adjustment in each direction (there's a similar arrangement in the carriages, but only 1mm each way).
I also had to do a bit of 'fine tuning' with a newly ordered 16mm dia bit to counterbore for the hex screwheads. I thought modelling the fasteners in sketchup would be going a bit too far - I was wrong!!
Getting it all fitted up and adjusted was a little fiddly, but not as bad as it could have been! :clap:
And it rolls fairly smoothly.... A bit of a relief!
Pics:
1) Fitting the first X rail
2) Counterbore for screwhead clearance (oops)
3) Looking along one of the rails
4) The whole machine, with Y rails drilled ready to do the whole thing all over again on another 2 axes
Right, I'm off camping for the weekend,
TomLast edited by Tom; 03-01-2010 at 04:31 PM.
30-05-2009 #12
Builds lookin good mate,
As for your spindle, I'm now qualified to say get a Kress!, I know you were going to come over the other week to here my Trend T3, Since then the bearings gave way and I'm now the proud owner of a Kress 1050 thanks to a little trade with Steve.Hilton
It makes half the noise and has twice the power, Soon as I picked it up I knew it was a qaulity item (pretty heavy though).
Michael.
31-05-2009 #13
31-05-2009 #14
Well you could pi..............no we won't go down that route
.John S -
31-05-2009 #15
So that wasn't suds you were using on your Bridgeport then John?
31-05-2009 #16
31-05-2009 #17
Possible to simplify a design I don't split my brackets.
I drill the side hole first and put a bolt and nut thru and tighten it up, then bore the 43mm hole.
Lastly I cut the head off the bolt so the stud with cutaway can move and clamp.
Just like a tailstock barrel clamp.
Saves a slitting or sawing operation, did I mention I was idle ?
Not noticed mine getting hot but it's only the 800w model, never run more that 6mm cutters so couldn't see the reason to go biggerJohn S -
31-05-2009 #18
Nice clamp John, not seen any made this way before.
Michael.
31-05-2009 #19
Yes it's a .cad format that will only open if someone has got Bobcad.
took the liberty of getting a jpg from it.
I presume the small circles are for a top mounting plate ?
.John S -
31-05-2009 #20
By Richard in forum Machine DiscussionReplies: 2Last Post: 18-02-2014, 04:18 PM
