    jonm's Avatar
    Location unknown. Last Activity: 19-06-2011 Has been a member for 9-10 years. Has a total post count of 89.
    hi tom
    could you tell what breakout board you used with the euro arc trader drivers, i looked at these are they ok
    thanks
    Tom's Avatar
    Lives in Nottingham, United Kingdom. Last Activity: 11-11-2023 Has been a member for 9-10 years. Has a total post count of 176. Referred 1 members to the community.
    Hi Jon,
    I'm very happy with the drivers. I've not worked them hard yet, but they have a decent feel of quality. They're on offer at Arc Euro at the mo - For £39 I can't find a complaint...
    I bought a readymade breakoutboard from DIYCNC (PCPPS-2). This is the simple board which is not opto-isolated. As far as I remember the inputs to the drivers are opto-isolated so I decided there was no need to double-up. Also I have a scrapper of a PC running EMC2, and I'm not doing anything commercial, so the consequence of a fried motherboard is not too serious (also unlikely).
    I got the one with a charge pump to improve safety, and it also has a voltage regulator to provide 5V for the limit switches, which is handy...
    jonm's Avatar
    hi tom
    thanks for reply i am using the system 3+ board from diycnc
    with 3nm steppers board limit is 30v , i think i could do with more voltage on these steppers , its always good to hear positive feedback before you buy, £39 each aint bad may give em a try
    thanks
    Tom's Avatar
    The shakedown runs of this router are finished, and I'm growing in confidence with it.... Purely for posterity here is a before screengrab from sketchup, and an actual photo of the thing for real! (complete with deadly MDF dust)
    There are a couple of weaknesses with it so far. Some are easy to build out with some re-cut panels, which I'm in the process of doing. Others are slightly more fundamental (but happily, not too serious).
    Improvements to make:
    1) The gantry is not sufficiently strong along the Y direction. Looking at it now it's obvious! But there are no diagonals, and I'm re-cutting these before even attempting alu. If you remember, this is supposed to be an alu sandwich router, but it's going to need gantry #2 before I can cut the alu for gantry #3...
    2) The X leadscrew is not perfectly straight (well actually, bent!), and combined with the poorly braced gantry leads to wavy sides (pitch of 4mm!) on the x edges of parts I cut. Hopefully the braced gantry will fix this. If not, a new screw....
    3) Some poorly placed drill-holes during the initial build means that at the moment the Z axis sits a couple of degrees away from vertical. The collet end of the router hands back under the gantry. Again, some re-cut panels (with computer aligned holes, not pencil aligned ones) will solve this.
    4) The final, slightly more thorny problem is that the Y rail support twists slightly (tucks under) in the x direction, when the router is at full Z travel down. The problem is worst in the centre of the Y travel. A fix to this would involve spacing the Y rails further apart, and re-drilling the Z carriage to accept new skate bearing positions. It's not impossible, but I will try alu skinning first, possibly followed by replacing that piece of MDF with a chunk of solid alu if that doesn't work (it's only 100mm x 700mm).
    Current max axis speeds are (so I don't forget):
    X 40mm/s, accel 80mm/s/s
    Y 100mm/s, accel 110mm/s/s
    Z 30mm/s, accel 60mm/s/s
    X and Z are conservative, put there to stop the machine shaking itself to bits with a wobbly gantry and bent screw. I hope to increase these as the improvements are added...
    A happy speed I've found for cutting MDF so far is 1800mm/min, with a 6mm 2flute mill, and 4mm of cut on each pass. This is definitely limited by the current rigidity of the machine, but onwards and upwards... Rooolll on the improvements....
Name:	Sketchup model.jpg
ID:	1223   Click image for larger version.
Name:	PC102241 [1280x768].JPG
    Tom's Avatar
    Here's the first really pleasurable job i've done on it... This was fun, a small oak box as an xmas present...
    Pics:
    1) ProgeCad
    2) CamBam
    3) EMC2
    4&5) The finished article (too many straight lines though )
    (oh by the way, there was some belt sanding involved - unfortunately didn't come off the machine looking like that! :)
Name:	ProgeCAD OakBox2.jpg
ID:	1225   Click image for larger version.
Name:	CamBam OakBox2.jpg
ID:	1226   Click image for larger version.
Name:	EMC2 OakBox2.gif
ID:	1227   Click image for larger version.
Name:	PC102248 [1280x768].JPG
ID:	1228   Click image for larger version.
Name:	PC102250 [1280x768].JPG
