    This may sound a stupid question but I am new to playing with stepper motors and drivers. I am hoping someone can help with my query. Basically I bought some stepper driver boards off Fleebay. The drivers have 6 connectors for the outputs. These are:-
    - Enable +
    - Enable -
    - Direction +
    - Direction -
    - Pulse +
    - Pulse -
    I only have 4 connectors on my breakout board, these are
    XE - enable?
    XD - direction
    XS - Pulse/step
    XN - Ground
    Would I be right to assume the three negatives are linked together and then back to XN?
    Steve
    Lives in Marple Stockport, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,346. Received thanks 618 times, giving thanks to others 87 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by swood1 View Post
    - Enable +
    - Enable -
    - Direction +
    - Direction -
    - Pulse +
    - Pulse -
    XE - enable?
    XD - direction
    XS - Pulse/step
    XN - Ground
    Steve
    Generally enable does not need to be used so just ling the -ve on the others. ..Clive
    I learnt my lesson with floating inputs 30 years ago, so my question is - is there usually built in bias towards the enabled state in stepper drivers ?
    Hi Clive,
    Thanks I shall give it a go, see what happens.
    In my Leadshine manual it says, High level for enabling, low level for disabling. Usually left unconnected (enabled)
    So the default state you might say is 'enabled', I expect that rather than floating, the input has a pull-up resistor to keep it 'high'
    Thanks' for that it saved me replying I do use my enables but as you say it is not necessary. ..Clive
    So let me get this correct. Do I only connect the following:-
    Direction - to XD
    Pulse - to XS
    All other connections are left disconnected.
  8. There are a couple of options but the common one is:
    Pulse+ to XS, Pulse- to XN
    Direction+ to XD, Direction- to XN
  1. Replies: 1
  2. 3 wire stepper motor drivers?
    Last Post: 17-08-2013, 10:01 PM
  3. Stepper Motor Wire Colour Codes
    By c cunningham in forum Stepper & Servo Motors
    Last Post: 26-01-2011, 02:13 PM
  4. common wire on stepper motor question
    By progomez in forum Motor Drivers & Controllers
    Last Post: 27-10-2009, 11:56 PM
  5. Stepper Motor Driver v2.3 2A $20 !!!
    By Lee Roberts in forum Motor Drivers & Controllers
    Last Post: 17-05-2009, 10:57 PM
