Thread: New Member
    Sounds like the right scale of thing to do on something like a second-hand Denford CNC mill? They do appear on the market from time to time. New, there are machines from Amadeal, ArcEuroTrade, Axminster, etc, if buying new fits your business model better. But a build log if you roll your own would be interesting to see!
  2. The Following User Says Thank You to Neale For This Useful Post:
  3. #2
    To be honest I wouldn't go with converting a mini mill for this work. End of the day they are toys and over priced toys at that. You would basicly end up scraping half the machine just to get it to perform any thing like acceptable. Even then you will still be left with sloppy dove tail ways needing constant adjustment to keep accurate.
    With your knowing exactly the purpose of the machine and your small work requirements then you could build a far stronger and more accurate machine custom to your needs that use's quality profiled linear rails, ballscrews and all the trimmings for less money than buying and converting minimill.
    if building id also consider going for a fixed gantry type ,Ideal for the sizes your working with,easy to knock up and will only require one ballscrew and stepper motor on the X axis.
  5. #4
    If Building, I am sure that a fixed gantry machine would be best for you, but I personally think that you would be better to go down the milling machine route, not a manual machine converted, but a purpose made CNC mill. Something like a Boxford or a Denford machine. There are quite a few that have already been changed to run with Mac3, but I understand that the later machines used a usb interface and had good CASD/CAM software. G.
  6. #5
    I know a guy with a Denford nova mill on a stand with plastic roll over cover including the software (probably needs converting to Mach3) I am sure it has ball screws all round. It looks very clean. If anybody is interested I will pm his number. ..Clive
