    Dont know if any one can help but im looking for some advice on turning a part on a lathe
    basically i need to bore the same size holes in the pinion on the top as the one on the bottom and then shorten the shoulder and then continue the thread.
    the holes need to be accurate an a really good fit so there is no play but the hole sizes are not a standard drill bit. (12.68mm)
    I have a lathe all be it not that great so a little concerned about getting it right however at least the pinions are relatively cheap but not to sure what sort of tool i would be best to do it with? drill a smaller hole first then enlarge it some how?
    Im think the shaft will be a little harder though and assume that the shaft will be hardened in some way?
    best regards
ID:	13230   Click image for larger version.
  1. 2 turning ops or more on solidcam?
    By eamo1978 in forum Solidworks
    Last Post: 25-06-2014, 10:57 AM
  2. RFQ: Small turned part. Cross drilled. quotes or advice please.
    By jimbo_cnc in forum Projects, Jobs & Requests
    Last Post: 23-06-2014, 08:41 PM
  3. RFQ: Parts need turning
    By ams in forum Projects, Jobs & Requests
    Last Post: 15-01-2014, 12:27 AM
  4. RFQ: Some turning required please
    By drumsticksplinter in forum Projects, Jobs & Requests
    Last Post: 16-04-2013, 06:15 PM
  5. Why do I get a taper when turning?
    By irving2008 in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 16-12-2012, 10:48 PM
