Page 2 of 2 FirstFirst 12
    There's an application out there somewhere that uses tapered (pointed) cutters with the work at a shallow angle allowing a huge variety of conventional and unconventional dovetails to be cut on quite long workpieces.
    From what I recall it's capable of the forms you can only otherwise create with a saw & chisel, i.e. blind dovetails with sharp corners and flat bottoms in the pockets.
    - Nick
    Tailmaker - http://tailmaker.net/
    But it does not make real dovetails joints.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    Gerry, try this.
    Half lap
    Same joint with decorative inlay
    Yeah its Tailmaker. I remember seeing some info on it on cnczone a while back.
  5. #15
    Cutting some hardwood samples to end up as website photos. African mahogany and flamed birch.
    Very clean cuts, and very tight fit.
ID:	13220Click image for larger version.
ID:	13221Click image for larger version.
    Gerry
  6. The Following User Says Thank You to Ger21 For This Useful Post:
  7. #16
    After almost 2 years of working on this, I finally have a website up and running.
    http://g-forcecnc.com/jointcam.html
    Gerry
  8. #17
    Hi Gerry
    Nice to see it up and running, i would just like to make a comment.
    I use an old Windows XP PC with Firefox Browser, when i go to your site i find it does not fit the size of my screen and i have to scroll left right to read it, don't know if it's a setting on my computer but it is a tad annoying. Other than that great job.
    Mike
  9. #18
    Mike, what's your screen resolution set to? Gerry's site displays perfectly on my screen with IE11.
  10. #19
    I made a decision to make the width of the screen 1200 pixels wide, assuming that it would work on just about any screen these days.
    Don't make assumptions.
    I found after it was done that it doesn't fit on an Ipad2 either.
    I doubt that I'll change it to accommodate a small percentage of people with old PC's.
    Gerry
  11. #20
    No worries Gerry
    Unfortunately i don't have a CNC router so will not be using it until i am so endowed, but have been keeping an eye on the thread for future reference.
    My res is 1024x768.
    Regards
    Mike
  1. wooden joints
    By luke11cnc in forum Woodwork Discussion
    Last Post: 18-10-2012, 11:59 PM
  2. Interested in and available for on site machining
    By themachinist in forum General Discussion
    Last Post: 25-09-2012, 11:27 AM
  3. NEW MEMBER: Have woodwork, looking for a router owner who may be interested
    By Lance in forum New Member Introductions
    Last Post: 08-06-2011, 01:28 PM
  4. Bolted Joints and Thread Fasteners
    By Lee Roberts in forum Gantry/Router Machines & Building
    Last Post: 01-04-2011, 09:53 AM
  5. NEW MEMBER: Hello Im interested in joining you all
    By Guisborough in forum New Member Introductions
    Last Post: 18-08-2010, 11:01 PM
