    Gerry,
    like this
    That's a very poor joint that I would never recommend. Too much end grain to end grain.
    Also, cutting joints like that with a router in solid woods is always problematic, as the wood will tend to chip where the bit exits the cut.
    That's also an issue in the wood joints you PM'd me about. Cutting a lot of those joints in solid wood is very difficult, unless you are starting with an oversized stock in both length and width, to allow trimming off the chipped edges.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
    I was thinking about a loose tongue now, similar to a biscuit but full width and shaped like the joint, probably plywood, that eliminates the end grain issue.
    The grooves in the end of the boards could be cut with a T slot cutter so they all lie flat on the table. but . . .
    With regard to the other cnc joints, I would never make them myself and you are correct about oversize, I like to take at least one shaving off with a sharp hand plane.
    There's an application out there somewhere that uses tapered (pointed) cutters with the work at a shallow angle allowing a huge variety of conventional and unconventional dovetails to be cut on quite long workpieces.
    From what I recall it's capable of the forms you can only otherwise create with a saw & chisel, i.e. blind dovetails with sharp corners and flat bottoms in the pockets.
    - Nick
    Tailmaker - http://tailmaker.net/
    But it does not make real dovetails joints.
    Gerry
    Gerry, try this.
    Half lap
    Same joint with decorative inlay
    Yeah its Tailmaker. I remember seeing some info on it on cnczone a while back.
  1. wooden joints
    By luke11cnc in forum Woodwork Discussion
    Last Post: 18-10-2012, 11:59 PM
  2. Interested in and available for on site machining
    By themachinist in forum General Discussion
    Last Post: 25-09-2012, 11:27 AM
  3. NEW MEMBER: Have woodwork, looking for a router owner who may be interested
    By Lance in forum New Member Introductions
    Last Post: 08-06-2011, 01:28 PM
  4. Bolted Joints and Thread Fasteners
    By Lee Roberts in forum Gantry/Router Machines & Building
    Last Post: 01-04-2011, 09:53 AM
  5. NEW MEMBER: Hello Im interested in joining you all
    By Guisborough in forum New Member Introductions
    Last Post: 18-08-2010, 11:01 PM
