    Episode 2 : making the control box and deep dive into the XSY AT1 inverter setup. Impressed so far (for the price) . .
  2. The Following User Says Thank You to routercnc For This Useful Post:
  3. #2
    Beautiful control box. Really enjoyed the vid.
    Small comment re: the pot they are usually 10K lin. not log. (I know you say not say log)
    I am pretty sure you can go from forward straight to reverse without problems. The ramp up and down seems very conservative.
    Hi Clive,
    Thanks, I didn't know if people would find it interesting or not as it ended up quite long.
    I'm intrigued by the pot comment - did you hear me say 'log' or are you saying it is worth clarifying ? I'll need to watch it again ! There was a bit of audio clipping in places which might have made it sound like I said something else.
    The accel and decel rates are the defaults and yes you can switch between forward and reverse straight away and the inverter will ramp between them. I'll set those up when it is on the machine and driving all the correct inertia loads (pulleys, spindle, chuck, and large drill). There is a limit to the braking as it is all done inside the inverter (this model does not have external brake resistor option).
  5. #4
    No as I said in my post I said, you did not say log. But I mentioned it because if anybody used a log pot it would then not be a linear line for the speed increase.
  6. #5
    Ok understood. I may mention it in a future video anyway in case someone buys a log pot and wonders what is going on.
  7. #6
    RE: Machining 1050 plate it's better to cut thru it in a single pass using a slot mill rather than trying to mill it away.
  8. #7
    Ok thanks Dean I’ll try that next time ��
  9. #8
    Episode 2 : making the control box and deep dive into the XSY AT1 inverter setup. Impressed so far (for the price) . ..
    Thanks so much for this - I've ordered one of those inverters to run my vacuum pump and your explanation is a lot clearer than the Chinglish manual!
  10. #9
    Hi Voicecoil
    You are welcome. I'm impressed with it so far . . . .
  11. #10
    Hi Voicecoil
    BTW, what do you think they mean by the "intermediate frequency" in the green part of your table???
  1. Good quality pillar drill?
    By newtoid1986 in forum Machine Discussion
    Last Post: 19-04-2013, 01:40 PM
  2. Pillar Drill Restoration
    By Treemonkey in forum Machine Discussion
    Last Post: 24-03-2013, 07:42 PM
  3. pillar drill?
    By wilfy in forum Machine Discussion
    Last Post: 10-11-2012, 09:18 PM
  4. Something for the metalworking guys
    By John S in forum Computer Software
    Last Post: 21-06-2010, 11:00 PM
  5. Dead pillar drill...
    Last Post: 27-10-2008, 03:54 PM
