07-07-2014 #2
Thanks Jonathan but I'll pass thanks. I agree that the Eltek is overkill for the job in hand but it will have loads of headroom and probably still be as efficient as a linear psu.
I am intrigued though by your comment Jazz - why would you feel that a linear psu would suit steppers more ?
Robin
The Following User Says Thank You to Wobbin For This Useful Post:
07-07-2014 #3
07-07-2014 #4
Good point, I hadn't considered a regen situation.... we'll see what happens. I've got hold of a Axminster (Sieg) X2 which has ballscrews on the X & Y axes already, plus a set of drives and motors, just setting about sorting out the motor mounts and the Z axis bits. Just need 28 hours in the day at the moment....
Robin
07-07-2014 #5
That won't be an issue with these power supplies - if it was then it's quite easily mitigated anyway.
This one I presume? The motors look like the common 3Nm ones, in which case they would run faster on 75V, but you're limited to 48V by the m542 drivers so that's not an option without replacing the drivers and power supply. Should you decide that that's worthwhile, my offer still stands. Edit: Also, take the handles of when you use it as CNC, otherwise their inertia will significantly limit the acceleration you can get.
Do you know if the output of the power supply you have is isolated? If not could you do me a favour and check it? Given the intended application, I suspect they are, but would like to be sure...The manual doesn't say.Last edited by Jonathan; 07-07-2014 at 07:54 PM.
07-07-2014 #6
Yup, that's the one. Re the psu, when you say isolated can you be more specific ? It's isolated between AC in and DC out for sure as it's a switched mode design with meaty high freq. transformers. Does that help ?
Robin
07-07-2014 #7
New member looking for advice on a good quality machine (brand)
By steve78 in forum Marketplace DiscussionReplies: 1Last Post: 16-08-2014, 09:25 PM -
Good quality pillar drill?
By newtoid1986 in forum Machine DiscussionReplies: 6Last Post: 19-04-2013, 01:40 PM -
Minimal-cost Power Supply Strategy - Repurpose Laptop Power Supplies
By LoveLearn in forum General ElectronicsReplies: 0Last Post: 25-01-2012, 09:29 PM -
FOR SALE: 50V 20A Power supply
By Jimmybristol in forum Items For SaleReplies: 8Last Post: 30-05-2011, 11:01 PM -
power supply
By hitmythumb in forum General ElectronicsReplies: 6Last Post: 21-06-2009, 10:27 AM
