    Hi everybody
    Does anybody know if the hiwin carriages can be putted on the rail any way i want, or there is something i have to be carefull.
    I have noticed that the rail has arrows printed that show one side of the rail. Also carriages have one side milled flat and the other not.
    I ask this because i had a problem while designing in solidworks
    The problem is that the distance from the center of the hole to the side is 5,6mm for the one side and 6mm on the other.
    Those dimensions have been measured from the 3d cad file that hiwin let me download from the official hiwin site.
    I am talking about the hiwin HGH20CA carriage
    Any idea woul help
    Thank for your time.
    Vagelis
    The creative adult, is the child who survived
    The carriages should both be installed with the ground surface on the same side. Figure 2 on page 17 of their manual implies that the ground face on the carriage should be on the side of the rail that the arrow points to.
  3. The Following User Says Thank You to Jonathan For This Useful Post:
    Thanks Jonathan
    Very usefull information
    Vagelis
  5. #4
    Vagelis,
    The ground side of the rail is designed to butt up to a machined vertical face so that if the machined face is straight then the rail will also be straight. The carriages have a ground side as you explained and I used that face to measure from and to place my large T square on when I was getting everthing square.
  6. The Following User Says Thank You to EddyCurrent For This Useful Post:
  7. #5
    Thanks so far for your advices.
    I have another issue with my profiled rails
    On the rails i can recognize the following code HGR20H 301 8X-5c that i cant translate according the Hiwin guidway.
    HG means HG series
    R means that the rails are interchangeable( there is no master and subsidiary rail, both rails can be used the same)
    20 is the thickness of the rail
    H (that follows 20) must be the precision level of the rail I cant find out what the 301 8x-5c means. Does anybody have any idea?
    Here the photos that i took
    Thanks for your time
    Vagelis
ID:	12768Click image for larger version.
ID:	12765Click image for larger version.
ID:	12766Click image for larger version.
  8. #6
    Is the length 3018mm's?
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  1. WANTED: BK12 Bearing Block Wanted - 1 off
    By EddyCurrent in forum Items Wanted
    Last Post: 11-03-2017, 08:52 PM
  2. FOR SALE: HIWIN & THK guide blocks and rails
    By vigen20 in forum Items For Sale
    Last Post: 27-02-2013, 10:37 AM
  3. RFQ: Drill/Tap Guide Block for 15mm aluminium plate edges.
    By Wal in forum Projects, Jobs & Requests
    Last Post: 29-11-2012, 04:23 AM
  4. FOR SALE: New Hiwin HGH15 bearing blocks / carriages profile rail
    By Jonathan in forum Items For Sale
    Last Post: 06-11-2011, 05:26 PM
  5. Understanding the bearing block
    By Rogue in forum Rails, Guideways & Bearings
    Last Post: 28-08-2011, 03:14 PM
