07-07-2014 #1
Hi everybody
Does anybody know if the hiwin carriages can be putted on the rail any way i want, or there is something i have to be carefull.
I have noticed that the rail has arrows printed that show one side of the rail. Also carriages have one side milled flat and the other not.
I ask this because i had a problem while designing in solidworks
The problem is that the distance from the center of the hole to the side is 5,6mm for the one side and 6mm on the other.
Those dimensions have been measured from the 3d cad file that hiwin let me download from the official hiwin site.
I am talking about the hiwin HGH20CA carriage
Any idea woul help
Thank for your time.
VagelisThe creative adult, is the child who survived
07-07-2014 #2
The carriages should both be installed with the ground surface on the same side. Figure 2 on page 17 of their manual implies that the ground face on the carriage should be on the side of the rail that the arrow points to.
The Following User Says Thank You to Jonathan For This Useful Post:
07-07-2014 #3
11-07-2014 #4
Vagelis,
The ground side of the rail is designed to butt up to a machined vertical face so that if the machined face is straight then the rail will also be straight. The carriages have a ground side as you explained and I used that face to measure from and to place my large T square on when I was getting everthing square.Spelling mistakes are not intentional, I only seem to see them some time after I've posted
The Following User Says Thank You to EddyCurrent For This Useful Post:
12-07-2014 #5
Thanks so far for your advices.
I have another issue with my profiled rails
On the rails i can recognize the following code HGR20H 301 8X-5c that i cant translate according the Hiwin guidway.
HG means HG series
R means that the rails are interchangeable( there is no master and subsidiary rail, both rails can be used the same)
20 is the thickness of the rail
H (that follows 20) must be the precision level of the rail I cant find out what the 301 8x-5c means. Does anybody have any idea?
Here the photos that i took
Thanks for your time
Vagelis
12-07-2014 #6
Is the length 3018mm's?
Gerry
UCCNC 2022 Screenset
Mach3 2010 Screenset
12-07-2014 #7
No this is not the real lengh
I bought the rails with the help of friend that makes woodcrafting mahines.
He import rails from Italy for his macines so he accept to make an order for me too.
He told me that his provider ( of the rails ) has lengths of hiwin rails that can cut to any dimension according his customers orders.
My rails have dimensions
1840mm
1080mm
400mm
But they all have the same laser printed logo HGR20H 301 8X-5c
So it is possible that the provider of the rails cut the rails to the dimensions that i order from a piece that initialy was 3018mm.The creative adult, is the child who survived
WANTED: BK12 Bearing Block Wanted - 1 off
By EddyCurrent in forum Items WantedReplies: 7Last Post: 11-03-2017, 08:52 PM -
FOR SALE: HIWIN & THK guide blocks and rails
By vigen20 in forum Items For SaleReplies: 8Last Post: 27-02-2013, 10:37 AM -
RFQ: Drill/Tap Guide Block for 15mm aluminium plate edges.
By Wal in forum Projects, Jobs & RequestsReplies: 11Last Post: 29-11-2012, 04:23 AM -
FOR SALE: New Hiwin HGH15 bearing blocks / carriages profile rail
By Jonathan in forum Items For SaleReplies: 0Last Post: 06-11-2011, 05:26 PM -
Understanding the bearing block
By Rogue in forum Rails, Guideways & BearingsReplies: 10Last Post: 28-08-2011, 03:14 PM
