Thread: Reducing costs
  1. Don't see how you can use 2 motors on Y as Y is across the gantry. Also Nema 17 are generally lightweight, good for 3D printers but will struggle to pull a heavy router around through ply unless you're just tickling the surface. Anyway the cost savings will be negligible once you throw them all away and do it right... How big is this machine?
    I think that the OP is using the American XY convention, rather than the European. Do Americans stand in a different position when they use these machines? Just idle speculation!
  3. Southport UK, 6 posts in 6 years, started the rockcliffe in 2009 then tried to sell it partially built in 2010, has asked about Chinese drivers before in 2010 as well... no point in reiterating the answer, it hasn't changed. Tony, try using the search function, the Chinese question has been done to death. And if your Rockcliffe is using threaded rod a pair of cheap Nema17s aren't going to move it fast enough to cut anything harder than butter...
    My input ends with the words "Rockcliffe".!! . . . Only good for burning and then still under performs.
    6 posts in six years? Tried to sell it partially built? What relevant's does this have to my question about using 2 nema 17 on a 4 axis machine ? I sold my first 3 axis carcass true , but had forgotten I had alredy asked about Chinese moters , please note 4 axis as I understand it = 2 moters on the y (?) Axis I thought 2 17 moters in sync would be =to the job , obviously not but still your answer was the only one anywhere near to my question.
    So thanks!
    Happy are they who dream dreams and are willing to pay the price to see them come true.
    Quote Originally Posted by tonygagey View Post
    So thanks!
    I did wonder the same myself Tony and understood it to mean dual motor, single axis, I'm quite familiar with the Rockcliffe machines as I built a model A A few years ago now. Sorry about the response you received from others.
    Have a search on the forum if your thinking about the TB driver system as there is two threads I know of that talk about this board, if it's another board let us know which and we may be able to advise, get yourself nema23 motors the 3Nm version, they cost more I know but they will serve you well and allow you to make use of them in the future if you do decide to build something new and quite a bit more substantial, their pretty much the "go too" motor for these machines.
    .Me
    Well bullit bit! Ordered system 4 from roy at diycnc. Just waiting for him to post when power supply in.
    Also going to build new carcase using Dave Gatton's Sidewinder plans. To ensure accuracy I am having the plans made as a pattern laser cut in 2mm steel. Expensive but I think it will be worth it !
    WHAT.!! . . . Are you for real.! Your going to waste money laser cutting steel templates to build a machine made from PAPER.!!
    For the price of the laser cutting/templates you could buy all the steel needed to build the frame and have 50X stronger machine. Bolt it together if you cant weld or have someone weld it for you.
    Also can I just say you are going about this all wrong regards the electronics. Roy's stuff is ok but it's more suited to smaller machines like Mills not routers. This is because the drives are low voltage with a Max of 40Vdc I believe. Routers run much higher feed rates than mills so we need more speed from the motors and steppers get there speed from volts. 40V max drives will be restrictive to a router machine unless you use a high pitch ball or lead screw and this will lower resolution so your getting a unbalanced machine.
    Trying to cut costs on electronics is asking for trouble and never ends well.!!
  1. Reducing 12v DC to 0.5V DC no more than 1A draw
    By AdCNC in forum General Electronics
    Last Post: 31-12-2022, 08:14 PM
  2. Rough idea of costs to build a medium size router.
    By jimbo_cnc in forum Gantry/Router Machines & Building
    Last Post: 27-06-2014, 01:18 PM
  3. Router costs (part 93 - Bits)
    By mocha in forum Tool & Tooling Technology
    Last Post: 29-05-2012, 10:23 PM
  4. Running costs of CNC machines?
    By .kyle in forum General Discussion
    Last Post: 19-05-2011, 08:05 PM
