Thread: Not quite a new member but...
Can't honestly answer that question because there's far more too tolerence than just the screws or rails you use.! Machine Design and build quality all play big part in this. I can tell you cheap chinese round rail is far inferior to profiled linear rail so if your chasing high tolerences then forget round rail.
Also If your on a budget then Chai at linear motion bearings is now selling Profiled linear rail at very good prices which makes using round type pointless. I've used loads now and they are good for the money. Not quite Hiwin quality but much cheaper and not far behind.
If you need high tolerences then you need a very ridged and stiff machine in which case provided the size required isn't huge then a fixed gantry machine is much better design.Last edited by JAZZCNC; 11-07-2014 at 05:33 PM.
11-07-2014 #2
Ive had a look on chai's ebay.com shop, Ebay.co.uk shows nothing in his shop for some reason but even on the us site all I can see is supported round rail, no profile rails at all? does he have a shop other than ebay?
Thanks, Charlie
11-07-2014 #3
