12-07-2014 #6
I just edited my post having re-read the datasheets. The leadshine 16mA is a max value when using > 5v sources, used to calculate the additional external resistor, its not relevant here. On a true 5v drive with an open collector sink, the current will be 10mA. Using the existing BOB as a sink should work as would your additional output transistors (messy though). Timing isn't going to be an issue...
The Following User Says Thank You to irving2008 For This Useful Post:
bumping holding current - how it affects torque?
By dsc in forum Stepper & Servo MotorsReplies: 7Last Post: 03-02-2014, 04:11 PM -
TB6560 auto current reduction
By Mjolinor in forum Motor Drivers & ControllersReplies: 1Last Post: 08-12-2011, 09:53 PM -
Current Set Resistors.
By NzOldun in forum Motor Drivers & ControllersReplies: 1Last Post: 20-06-2011, 08:38 AM -
G540 Current set resistors
By blueseidboy in forum Motor Drivers & ControllersReplies: 3Last Post: 23-08-2010, 02:21 PM -
Simple Current Limiter (LM317)
By Mad Professor in forum General ElectronicsReplies: 14Last Post: 13-07-2009, 10:01 PM
