09-07-2014 #3
Silyavski, I'm having similar issues, maybe my basic explanation will help if my problem can cast a common light on the issues?
I have 2 NPN proximity switches, each a 3 wire switch.
I set up a simple bench test with a 12v PSU and connected proximity switch brown to +ve and proximity blue to -ve then I used a simple continuity tester across the proximity black and brown.
As the proximity senses a metal target, the continuity test works as I would expect.
Then I set up Mach and the inputs so that I can see the BOB inputs are working on the Mach diagnostics screen.
Also the proximity switches light up with thier little LED, they work with a continuity test.
BUT when I connect a -24ve to the proximity switch and the Bob on one pin, and the poximity black to the other Bob pin, nothing happens in Mach.
Any ideas?
Proximity switch NPN or PNP
By Matt81 in forum General ElectronicsReplies: 9Last Post: 19-04-2014, 11:38 AM -
Proximity Wiring Problem
By Bruce in forum General ElectronicsReplies: 7Last Post: 13-01-2014, 07:21 PM -
Proximity Switches
By kingcreaky in forum General ElectronicsReplies: 20Last Post: 23-10-2013, 01:30 PM -
Proximity sensor help required
By plasticsales in forum General ElectronicsReplies: 12Last Post: 21-08-2013, 07:02 PM -
Proximity Sensors as Limit Switches ?
By Lee Roberts in forum General ElectronicsReplies: 5Last Post: 03-10-2009, 07:04 PM
