Thread: Flasher circuit using a BD679
11-07-2014 #11
This is the info that Bruce is using for his machine, see the Zip file attachment for the Brains.
http://www.mycncuk.com/threads/6565-...2213#post52213
Brains are a feature of Mach3 software, you can get an overview here;
The Following User Says Thank You to EddyCurrent For This Useful Post:
11-07-2014 #12
I had an issue with a PMDX A few months ago with prox switches on Home switches (Inputs) not being pulled to ground and the cure was a small resisistor between ground and the pin. It sounds like you are having a similiar thing so worth a try.?
12-07-2014 #13
Jazz... close I think.....
It is now working after receiving an email from Steve @ PMDX. In his email he indicated that I needed to connect the negative from the 24v supply to GND so the transistor had a reference to it. I did that and it works. I now know why Eddy's worked from the start (at least I think I do), his BOB is powered by the same 24v supply as the flasher circuit and therefore the tx already had a reference to the 24v neg side. I am thinking now if I replaced the 24V LED with one suited more to 5v whether it would work without grounding to the supply. However, that would probably be a moot point given that I have a PMDX 126 winging its way to me as we speak and it is powered by 240v.....
Thanks to everyone who ran around in circles with this, I really appreciate the help given
Bruce
12-07-2014 #14
12-07-2014 #15
And with me being a follower and not a guru in electronics I managed to completely miss that principle. Lesson learned I can tell ya because now I just feel like a wally :)
12-07-2014 #16LOL... when I was fixing drives a while back I had that very phrase on a label on my bench to remind me :-)Assumption being the mother of all F'#&up's
No 0v reference - yep, that would do it. We've all been there. Glad you're sorted.
Robin
AM882 Alarm Circuit
By Wobblycogs in forum General ElectronicsReplies: 8Last Post: 28-03-2014, 06:06 PM -
-10V to 10v circuit
By vre in forum General ElectronicsReplies: 17Last Post: 15-01-2014, 12:15 AM -
E-STOP Circuit - will this cause any problems?
By birchy in forum General ElectronicsReplies: 34Last Post: 18-12-2012, 04:35 AM -
DC motor drive circuit?
By Tenson in forum General ElectronicsReplies: 4Last Post: 02-02-2012, 10:32 PM -
Milling Printed Circuit Boards - How To
By Lee Roberts in forum Electronic Project BuildingReplies: 0Last Post: 28-08-2008, 11:25 PM
