    Quote Originally Posted by Wobbin View Post
    What's the 'brain' function then ? Forgive what may be a dumb question, as I said I'm new to CNC...
    This is the info that Bruce is using for his machine, see the Zip file attachment for the Brains.
    http://www.mycncuk.com/threads/6565-...2213#post52213
    Brains are a feature of Mach3 software, you can get an overview here;
  2. The Following User Says Thank You to EddyCurrent For This Useful Post:
  3. #2
    I had an issue with a PMDX A few months ago with prox switches on Home switches (Inputs) not being pulled to ground and the cure was a small resisistor between ground and the pin. It sounds like you are having a similiar thing so worth a try.?
    Jazz... close I think.....
    It is now working after receiving an email from Steve @ PMDX. In his email he indicated that I needed to connect the negative from the 24v supply to GND so the transistor had a reference to it. I did that and it works. I now know why Eddy's worked from the start (at least I think I do), his BOB is powered by the same 24v supply as the flasher circuit and therefore the tx already had a reference to the 24v neg side. I am thinking now if I replaced the 24V LED with one suited more to 5v whether it would work without grounding to the supply. However, that would probably be a moot point given that I have a PMDX 126 winging its way to me as we speak and it is powered by 240v.....
    Thanks to everyone who ran around in circles with this, I really appreciate the help given
    Bruce
  5. #4
    Quote Originally Posted by ozspeedway View Post
    Ah ah.!! . . . Assumption being the mother of all F'#&up's me and suspect others presumed you would be doing this as it's a given that you must use the same ground for any circuit to work correctly.!
  6. #5
    And with me being a follower and not a guru in electronics I managed to completely miss that principle. Lesson learned I can tell ya because now I just feel like a wally :)
  7. #6
    LOL... when I was fixing drives a while back I had that very phrase on a label on my bench to remind me :-)
    No 0v reference - yep, that would do it. We've all been there. Glad you're sorted.
    Robin
  1. AM882 Alarm Circuit
    By Wobblycogs in forum General Electronics
    Last Post: 28-03-2014, 06:06 PM
  2. -10V to 10v circuit
    By vre in forum General Electronics
    Last Post: 15-01-2014, 12:15 AM
  3. E-STOP Circuit - will this cause any problems?
    By birchy in forum General Electronics
    Last Post: 18-12-2012, 04:35 AM
  4. DC motor drive circuit?
    By Tenson in forum General Electronics
    Last Post: 02-02-2012, 10:32 PM
  5. Milling Printed Circuit Boards - How To
    By Lee Roberts in forum Electronic Project Building
    Last Post: 28-08-2008, 11:25 PM
