Thread: Usb smooth stepper
25-11-2016 #13
Yes no problem. If your tearing belts apart then something was very wrong. 2 ballscrews and 30Kg is nothing for belt drive. I use this method all the time with 2 x 20mm 10mm pitch ballscrews and never have any trouble with belts tearing.
Q1: 15mm HTD belts are what I use. Pulley size depends on machine but often I use 18 or 20T. Try to keep the pulley size small possible to lower inertia but keep in mind shaft size so don't go too small.!
Q2: Simple to answer because I've just built two identical machines using the same setup.
IP-M and with belt drive using 4.5Nm Nema 34 motors turning 20mm dia 10mm pitch screws with 1.25:1 ratio (16T on motor 20T on screws)
how to smooth stl model, smooth curves out of straight lines
By chris in forum DeskProtoReplies: 4Last Post: 21-01-2014, 11:00 PM -
Smooth Steppers are finally available in UK !
By rnr107 in forum Marketplace DiscussionReplies: 63Last Post: 13-07-2012, 12:53 AM -
FOR SALE: Smooth Stepper board Plus C24 and C25 BOB
By AdCNC in forum Items For SaleReplies: 2Last Post: 11-09-2011, 09:56 PM -
FOR SALE: Smooth Stepper (UK)
By lateAtNight in forum Items For SaleReplies: 2Last Post: 24-06-2010, 10:19 PM -
better than smooth stepper
By Metalhead in forum Motor Drivers & ControllersReplies: 5Last Post: 21-06-2010, 06:43 PM
