Thread: Durability of a 6040 ?
Wouldn't do that or buy the spindle at same time because those brushed spindles are Crap and will fry within the weeked if pushed hard. BUT Then you also have other issues like mounting the spindle and running the cables. Those cheap 3020 machine with poxy spindles have no spare room in the energy chains for water pipes etc but worse the Z axis is often not designed to take the heavier spindle and you will have problems.
Worst thing you can do is go rushing in so just hold off the "buy it now" button and do some more reasearch. What's your budget.?
11-07-2014 #2
Well, I was very happy with £480 for 3040 (not 3020) when I thought that would do what I wanted.
£180 for water spindle and VFD is OK too, as that will carry over to my next machine I assume? although it doesn't seem to include pipes/pump/etc.
11-07-2014 #3
12-07-2014 #4
Loads of them for £450.
I haven't tried to work out if there are any differences yet.
Here's a 800W spindle/vfd. Any good ? Do I need 1.5kW ?
http://www.ebay.co.uk/itm/0-8KW-WATE...-/181270875660
http://www.ebay.co.uk/itm/MILLING-DR...-/250960628553
http://www.ebay.co.uk/itm/UPDATED-NE...-/330880647549
http://www.ebay.co.uk/itm/TOP-QUALIT...-/330880647715
http://www.ebay.co.uk/itm/CNC-3040-R...-/330880647628
http://www.ebay.co.uk/itm/CNC-ROUTER...-/250960627505
12-07-2014 #5
Here we have 4th axis and ballscrew (don't the £450 ones have ballscrews?)
http://www.ebay.co.uk/itm/4-axis-3D-...-/291019696713
and here we have water spindle too. for £1160
http://www.ebay.co.uk/itm/Latest-CNC...-/221347111338
I can stretch to that after a bit of time to adjust to the step up from what might have been a £450 purchase.
But is it £400 better than the £450 model with added spindle/vfd ?
12-07-2014 #6
Ok well there are several reasons why to stay away from the £450 models.
First they use Acme lead screw not ballscrews. Acme screw as much more inefficient and high backlash so you accurecy is poor plus they are only 4mm pitch so can't reach the feeds require for cutting plastics correctly. They wear out very quickly and become baggy n sloppy in no time.
Next the Z axis on just about all I've seen won't take the water cooled spindles and are one piece cast units that are very weak. To replace you'll virtually have to rebuild the machine.
The electronics are junk and under powered so won't stand the strain of heavier loads for prolonged periods.
I wouldn't go for any of these chinese machines unless they can take 80mm spindles and have ballscrews with at least 5mm pitch or better still 10mm thou I havent seen one yet that as 10mm.
11-08-2014 #7
Even though I've been considering a self-build copying someone else. I'm itching to get on with my real projects!
Lets forget the wish for aluminium cutting capability, and concentrate on my actual wood and Delrin needs.
If I go for a 6040 size with 1605 ballscrews and watercooled VFD spindle, then I get the choice of:
800W for £1090
http://www.ebay.co.uk/itm/331128096204?
or 1500W for £1390.
http://www.ebay.co.uk/itm/221376944050?
Do you think the 800W is enough for my Delrin milling work?
I'm mindful of what's been said about the electronics, so 1500W spec might be more likely to last. But also, they are covered by warranty, and if it lasts out the warranty year it's likely to last a bit more.
I'm nearly decided, just need some kind of approval from the forum, even if it's be-grudgingly given :)
What is your opinion of the CNC 6040 Router Machine ?
By John S in forum Chinese MachinesReplies: 7Last Post: 30-11-2023, 10:58 AM -
New 6040 owner looking for advice from others with a chinese 6040/3040
By itsmillertime in forum Machine DiscussionReplies: 12Last Post: 14-10-2019, 08:30 AM -
Chinese 6040 CNC Router Advise Needed
By Bob Hepple in forum Chinese MachinesReplies: 24Last Post: 27-11-2013, 12:00 PM -
suggested equipment to retro fit a 6040 yoocnc
By madprof1 in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 03-12-2012, 09:52 PM -
6040 router
By John S in forum Milling Machines, Builds & ConversionsReplies: 13Last Post: 01-10-2012, 07:18 PM
