    Here we have 4th axis and ballscrew (don't the £450 ones have ballscrews?)
    http://www.ebay.co.uk/itm/4-axis-3D-...-/291019696713
    and here we have water spindle too. for £1160
    http://www.ebay.co.uk/itm/Latest-CNC...-/221347111338
    I can stretch to that after a bit of time to adjust to the step up from what might have been a £450 purchase.
    But is it £400 better than the £450 model with added spindle/vfd ?
    Ok well there are several reasons why to stay away from the £450 models.
    First they use Acme lead screw not ballscrews. Acme screw as much more inefficient and high backlash so you accurecy is poor plus they are only 4mm pitch so can't reach the feeds require for cutting plastics correctly. They wear out very quickly and become baggy n sloppy in no time.
    Next the Z axis on just about all I've seen won't take the water cooled spindles and are one piece cast units that are very weak. To replace you'll virtually have to rebuild the machine.
    The electronics are junk and under powered so won't stand the strain of heavier loads for prolonged periods.
    I wouldn't go for any of these chinese machines unless they can take 80mm spindles and have ballscrews with at least 5mm pitch or better still 10mm thou I havent seen one yet that as 10mm.
    Even though I've been considering a self-build copying someone else. I'm itching to get on with my real projects!
    Lets forget the wish for aluminium cutting capability, and concentrate on my actual wood and Delrin needs.
    If I go for a 6040 size with 1605 ballscrews and watercooled VFD spindle, then I get the choice of:
    800W for £1090
    http://www.ebay.co.uk/itm/331128096204?
    or 1500W for £1390.
    http://www.ebay.co.uk/itm/221376944050?
    Do you think the 800W is enough for my Delrin milling work?
    I'm mindful of what's been said about the electronics, so 1500W spec might be more likely to last. But also, they are covered by warranty, and if it lasts out the warranty year it's likely to last a bit more.
    I'm nearly decided, just need some kind of approval from the forum, even if it's be-grudgingly given :)
    This 800W one is only £980
    http://www.ebay.co.uk/itm/190566922244?
    Only difference I can see to the £1090 machine is the gantry beam being made of sheet metal, which doesn't look as good to me, but do the guides provide the torsional stiffness?
    Anyone got experience of this machine?
  1. What is your opinion of the CNC 6040 Router Machine ?
    By John S in forum Chinese Machines
    Last Post: 30-11-2023, 10:58 AM
  2. New 6040 owner looking for advice from others with a chinese 6040/3040
    By itsmillertime in forum Machine Discussion
    Last Post: 14-10-2019, 08:30 AM
  3. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
  4. suggested equipment to retro fit a 6040 yoocnc
    By madprof1 in forum Milling Machines, Builds & Conversions
    Last Post: 03-12-2012, 09:52 PM
  5. 6040 router
    By John S in forum Milling Machines, Builds & Conversions
    Last Post: 01-10-2012, 07:18 PM
